| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
TPMS guy
Drives: `Cuda, S2000 & GR86
TC105X GR86/BRZ 17x9 specific track wheels!
![]() Weds Wheels North America is coming out with a new TC105X wheel that has a track focused offset for our beloved GR86/BRZ cars. This new wheel will be in the 17x9 5x100 size. I do not have the liberty to state the offset as Weds does not want to share info with other wheel manufacturers, but according to Weds it is a "perfect" square setup utilizing many popular 245-255 extreme summer/competition tires. "Perfect" as right in the center of the wheel well where it can maximize suspension travel & minimize lap times. According to Weds Japan's track testing, their current 17x9 +35 5x100 is not the optimal size for the ZN8/ZD8 chassis. Weds Japan is only making 10 sets of this version of the venerable TC105X specific for the 2nd Gen BRZ/GT86. All wheels will have the same great features as production versions of the TC105X such as light weight, knurled bead, generous brake clearance & will be offered in the EJ Titan finish. Matt at Speed Freaks USA is getting the sets & I have already paid for mine so there are only 9 or less left. These will not last long! Get your set here: https://speedfreaksusa.com/i-2390442...fic-5x100.html Funny thing is that I actually don't even have my GR86 yet & will probably get my TC105X wheels before my car arrives haha!
| The Following User Says Thank You to RylisPro For This Useful Post: | Ash_89 (10-05-2023) |
Drives: 22' Model
Hi Rylis! I recognize your name from S2ki, glad to see you've jumped on the GR86 board! These wheels are super tempting since i had the tc105n on my S2, but man i recall them being cheaper for that chassis?
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
lmao sure. only 10.
Either way, if they only make 10, big deal. I'm sure running the secret offset instead of the +35 will be the tenths-of-a-second difference maker for all of you pro racers who scoop them up.
NARFALICIOUS
Noob Poster 1988 | 2016 |
Drives: 23 BRZ
If it's the perfect offset I'm sure they'll go into normal production.
| The Following User Says Thank You to mike2100 For This Useful Post: | timurrrr (05-13-2022) |
#5 | |
TPMS guy
Prices have gone way up for everything due to all the global craziness unfortunately... Around $500 a wheel shipped for 17x9 TC105X is pretty much the going rate from any Weds vendors You may remember Matt Misencik from S2ki who operates Speed Freaks USA now as well as he notified me of the wheels. I'll make a video once I get my set in.
Drives: 2022 MT Neptune GR86 Prem.
Dude, you are totally violating the first rule of the super secret offset!
Drives: It has 4 wheels
So they're expecting people to pay for them without knowing what the offset will be?
I'm in the market for 17x9s and I like the TC105X better than all other available options. Having said that, I need to know what I'm buying. If I can get 17x9 +43 for the rear and 17x9 +36 for the front, I am 100% in haha. Due to the tight outer rear fit and tight inner front fit, there is no one single offset that works well for both front and rear on the Gen 2. You need different offset front to rear or spacers up front. |
| The Following 3 Users Say Thank You to bradsm87 For This Useful Post: |
Wheels for Brains
My guess is that they're going to make them +49. TC105X are already available in that spec for S2000; maybe they'll just cut the bolt pattern for 5x100 instead
#9 | |
They need to be somewhere between +45 and +42 for the rear and between +38 and +35 for the front. |
| The Following User Says Thank You to bradsm87 For This Useful Post: | PulsarBeeerz (05-13-2022) |
#10 | |
Wheels for Brains
17x9+49 has the same inside plane as 18x9.5+43, which is a common square size for wheels that many people run without issue provided they have coilovers (Enkei RS05RR, Volk Racing Wheels [TE37 SL even goes out to +45]): https://www.ft86club.com/forums/showthread.php?t=7535 For an order of "only 10 wheels," its not an outlandish possibility that this is a custom speedfreaksusa.com order that are simply a redrill to 5x100 (e.g. when you want a non-standard color, the manufacturer usually only sells them at a minimum order size of 10 sets). |
#11 |
Drives: 2022 Toyota GR86
ZN8 specific wheels I have seen so far are 18x9 + 51 for the TC4 and 18x9 +47 from Titan7.
#12 | |
TPMS guy
The guy I spoke with at Weds NA (thick Japanese accent, "Taz" I think is his name?) then asked me why I was getting the 17x8.5's for? as they were designed for the 1st gen GT86. I mentioned it was for the GR86 that hasn't arrived at my dealership yet. Taz then stated that WedsSport in Japan has been testing the new 17x9's & developed the new offset for the 2nd Gen GR86/BRZ. This new 17x9 is strictly for the track & is not a "flush" look that many US buyers go out to purchase & why only 10 sets made to test the market. If they don't sell these 10, then WedsSport Japan won't make them, basically supply & demand. I then told Taz that I wanted one of the 10 sets & he said that he would talk to Matt at Speed Freaks first to change my order. I contacted Matt in the afternoon to confirm my order & he mentioned that they were getting the 10 sets. I then put up forum posts on GR86.com forum & this forum to spread the news. Once I get my wheels & GR86 I'll make a video. If anyone is doubting, then call Weds NA in SoCal to verify. I could care less who else gets the wheels, as long as I get my set haha!
#13 | ||
Drives: Miata
#14 |
I don't think there is a magic offset that offers clearance in the rear and the front at the same time. You space the front or trim the rear or have different offsets front to back. This is assuming you are running a reasonable width tire (245/255).
| WEDS TC105X 17x9.0+35 special color batch, ETA November, Circuit Black and TS Bronze | Gruppe-s | Wheels and Tires | 125 | 11-23-2022 05:18 AM |
| Rare - Circuit Black Wedsport TC105X 17x9.0 SoCal - Pick Up Only | ericdavidchen | Wheels and Tires | 0 | 01-09-2022 08:54 PM |
| SOLD WedsSport TC105X 17x9+35 EJTI 5x100 with 255/40 Hankook Tires and more | hifiguy99 | Wheels and Tires | 10 | 03-05-2021 10:49 PM |
| WEDS TC105x 17x9.0+35 2018 EXCLUSIVE Gunmetal color, Japan made, rare & lightweight | Gruppe-s | Wheels and Tires | 52 | 07-29-2020 12:55 AM |
| WedsSport TC105X 17x9 +35 and TRD Springs | JeffFAFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 01-10-2020 08:46 AM |
