Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-16-2022, 01:44 PM   #253
mr.whiskers
Drives: '22 BRZ
Originally Posted by 22 BRZ View Post
Yeah, that just makes me think I need an alignment even more. Maybe next week. If it turns out that I've done 6000km with a bad alignment I will feel quite sheepish. However, for 90% of that time I was on aggressive winter tires, which throws the steering feel out the window anyways.
Yea I would check alignment. I don't find my to be twitchy at all
mr.whiskers is offline   Reply With Quote
Old 05-16-2022, 03:03 PM   #254
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
I just ordered some camber bolts, so I'll throw those on and take it for an alignment.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
The Following User Says Thank You to 22 BRZ For This Useful Post:
Dzmitry (05-18-2022)
Old 05-16-2022, 05:00 PM   #255
mr.whiskers
Drives: '22 BRZ
I should order some too before my first oil change appointment in June in Winnipeg so I can pick them up at that time.
Did they give you a timeline on how soon you should get it? I don't imagine it would take a long time, must be a common part.
Also might be a stupid question, how many you ordered? I understand its 2 per wheel? Do people usually do camber on all 4 wheels or front is enough?
Old 05-16-2022, 05:21 PM   #256
jvincent
jvincent's Avatar
You only need two bolts, one for each side on the front. You can't change the rear camber with bolts. You need to change the LCAs for the rear.
The Following User Says Thank You to jvincent For This Useful Post:
mr.whiskers (05-16-2022)
Old 05-16-2022, 05:35 PM   #257
mr.whiskers
Drives: '22 BRZ
Thank you
Old 05-17-2022, 01:00 AM   #258
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Not quite true about the rear: https://www.ft86club.com/forums/showthread.php?t=33415
The Following User Says Thank You to DocWalt For This Useful Post:
Ohio Enthusiast (05-17-2022)
Old 05-17-2022, 12:05 PM   #259
jvincent
jvincent's Avatar
Originally Posted by DocWalt View Post
Hmm, never saw that one.
Old 10-23-2022, 12:27 PM   #260
otter
Drives: 22 BRZ
My BRZ is a base model (Premium? Limited? Can't remember Subaru's stupid naming scheme). Had my door cards off yesterday to do a quick speaker swap and noticed that there's wiring and a blank panel there for a puddle light. Assuming this is something available on the upper trim and if so, looks like I'll have to find one to pop in there...
Unrelated, something I've noticed now that we're getting some "cool" mornings again (by TX standards) the quick flash turn signal issue is back. I don't recall seeing it all Summer but it started happening again last week when the cold front hit.
otter is offline   Reply With Quote
Old 10-30-2022, 11:57 AM   #261
Squirrely
Drives: 2023 BRZ, LTD, MT
Has anyone has issues with the 'door-open' chime? As least a few times per week it goes off when I open the door after the ignition is already off. It's really weird, as if I still have the car turned on. If I close the door and reopen it, it goes away.
Squirrely is offline   Reply With Quote
Old 10-30-2022, 08:39 PM   #262
AK2112
AK2112's Avatar
Drives: 22 BRZ
I have noticed this though I did not consider it an issue.
AK2112 is offline   Reply With Quote
Old 10-31-2022, 12:08 AM   #263
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
I just noticed this as well but only after reading about it here. About as non-issue as it gets tbh
Interceptor777 is offline   Reply With Quote
Old 10-31-2022, 12:21 AM   #264
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
It happens to me every now and then, but I always figured it was something I was doing, related to some sort of accessory mode, or it mistakenly thinks I left my key in the car.
CincyJohn is offline   Reply With Quote
Old 10-31-2022, 01:07 PM   #265
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Same here. I keep thinking it is some combination of conditions that cause it, but it happens randomly and so far isn't annoying enough for me put in the time to actually troubleshoot.
Desertnate is offline   Reply With Quote
Old 10-31-2022, 03:32 PM   #266
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
Mic's sensitivity is turned down too low
I think my mic's sensitivity is turned down too low. When I make phone calls in the car they say it is hard to hear me. I opened the dealer settings to look at my mic levels, I have to get really loud for it to register. If I scream as loud as I can, it never gets above 3 bars. Is anyone else having this issue?
Level 1 is at 85 dB.
Level 2 is at 95 dB.
Level 3 is at 98 dB.
Level 3 is at screaming as loud as I could is at 109 dB.
PhatFreshPrince is offline   Reply With Quote
BRAINDUMP - FT86 Quirks, common fixes and when things need upgrading Aztec Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2015 06:44 PM
Magazine features crouchy35 AUSTRALIA 1 06-03-2013 06:59 PM
Interesting features on the FR-S... Senzai Scion FR-S / Toyota 86 GT86 General Forum 59 05-08-2013 05:41 PM
Strange Quirks Aznek Scion FR-S / Toyota 86 GT86 General Forum 30 08-15-2012 10:40 AM
FR-S Standard Features zAnSh1n Scion FR-S / Toyota 86 GT86 General Forum 182 04-04-2012 05:23 PM
