Old 04-21-2022, 10:13 AM   #29
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by MacSpeed View Post
Cant on a uhaul trailer. Their really shitty and weight 2000-2500# empty and force a ton of tongue weight for "Safety"
When I would tow my S2K with one of those an my Tacoma it was the same deal. Borrowed a friends Trailx one time and was able to load it properly and the Taco sat flat no issues.
If sticking with uhauls, best bet would be one of those nice adjustable hitches that you can raise up vs the drop that hitch has.
I just got a cam superline and a wdh and it is a world of difference from a uhaul. Minus the harsher ride it is barely noticeable anything is back there. So what prevents that? Id assume my curt would still be able to hook up to a uhaul
Old 04-21-2022, 11:30 AM   #30
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
I never really messed with WDH but thought they had to be attached to the tongue and with the surge brakes and other stuff there I don't think it'll work. Be an expensive gamble while trying to be cheap/budget renting a trailer.
MacSpeed is offline   Reply With Quote
Old 04-21-2022, 12:45 PM   #31
Breadman
Breadman's Avatar
Mine is like this and i guess bypasses? my 7 pin plug and where the surge brake would be. I would highly recommend it. I havent used the anti swap bar yet tho
Old 04-21-2022, 03:00 PM   #32
Eric1855
Drives: LP DSP / CSP '13 BRZ
There are some WDH that work with surge brakes, but just like working with reverse, you need to make sure you pick the right one when shopping.
The issue with any UHaul/Rental trail though will be can you attach the trailer side anchors. Some come with U-Brackets with set bolts that could work on anything, but others require drilling into or through the from so just need to look for that too. Also most will specify a distance from the hitch ball you need to mount those anchors so you'll need to measure that too for trailers with a short tongue.
Eric1855 is offline   Reply With Quote
Old 05-07-2022, 09:18 PM   #33
jflogerzi
jflogerzi's Avatar
Just towed for the first time with my new Ford ranger and uhual trailer. Factory suspension and everything looked good. Here is a picture of the setup. No problem with no WDH. Everything looked pretty level.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
JD001 (06-05-2022)
Towing your 86 ka-t_240 Tracking / Autocross / HPDE / Drifting 70 03-01-2024 07:52 PM
Towing with the FR-S tobkin Scion FR-S / Toyota 86 GT86 General Forum 36 08-21-2020 01:08 PM
Towing a FRS Lunatic Scion FR-S / Toyota 86 GT86 General Forum 7 07-24-2014 10:55 PM
Towing with the FR-S CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 23 07-18-2012 09:34 AM
