Old 05-16-2020, 12:36 AM   #1
EvolutionRevolution
Drives: SCION FRS 2016
Flex fuel kit DT vs CSG/Ptuning
Thoughts on best flex fuel kit? Right now I'm between Delicious and the one by Ptuning at CSG. THANKS.
EvolutionRevolution is offline   Reply With Quote
Old 05-16-2020, 12:06 PM   #2
FunnyGopher
Drives: 2015 BRZ Limited
I have an earlier DT kit that bolts closer to the fender. I think their new ones are mounted on the factory strut brace. I like it as far as sensors go. Really hasn't given me any problems. The lines look nice. Nothing about it makes you think it was thrown together quickly. It looks professional when installed correctly. The one downside of the kit, if it really matters to you, is the inability to wire up a physical gauge if that's something you were looking for. They have a mobile app that can tell you the ethanol content over Bluetooth, and that's been suffice for me. At one point I think I had figured out how to wire a physical gauge up, but it required custom cable harnesses and additional components. So it's definitely possible, just not off the shelf from their kit.
However, I love all the stuff CSG endorses, and I would trust them if they endorsed the PTuning kit.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 05-16-2020, 04:06 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
I have xero-limit FF kit. Seems to be the cheapest option that also includes an independent Zeitronix Ethanol% gauge. Easy install, fittings all look to be good quality. Uses the same Zeitronix sensor/eca as most the other kits. I’d either go this kit as it’s probably the cheapest high quality kit (do to buying in bulk and having cheaper labor costs in that state vs other states, not cheaper because quality) or just support whoever is tuning your car and get whatever kit they provide. In my case it happens to be both.
Old 05-16-2020, 06:26 PM   #4
CSG Mike
CSG Mike's Avatar
The old DT kit is what I have on my car, but that's not the kit that is sold at this time by DT.
The Ptuning kit uses a Continental sensor, which is OEM grade (it's used on GM flex fuel cars), as does the DT kit I have. I would recommend the Continental over the Zeitronix for consistency and reliability.
Goingnowherefast (05-16-2020)
Old 05-17-2020, 11:13 AM   #5
Chuckls
Moutain Runner
+1 for Ptuning due to it's stealth installation.
Chuckls is offline   Reply With Quote
Old 04-19-2022, 07:44 PM   #6
DocRecon
Muscle Car to Import
DocRecon's Avatar
Drives: 2013 Asphalt FR-S
I just wanted to bump this post up because the PTuning kit and CSG are top-notch. Zach is a tuning god and goes well beyond being helpful. CSG rocks! ��
DocRecon is offline   Reply With Quote
Old 04-19-2022, 07:53 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The PTuning kit is nice but don't get the ethanol content display. Mine lasted a month.
Old 04-20-2022, 10:55 PM   #8
AllThePeat
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
+1 for PTuning/CSG as well. Working with Zach is a pleasure and the tune is amazing!
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily
AllThePeat is offline   Reply With Quote
The Following User Says Thank You to AllThePeat For This Useful Post:
DocRecon (06-27-2022)
Old 05-06-2022, 08:03 AM   #9
iTrytoBefast
iTrytoBefast's Avatar
Drives: Toyota 86 2018
I’ve had the PTuning flex fuel kit with display for over a year. No problems.
iTrytoBefast is offline   Reply With Quote
Old 05-11-2022, 12:03 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Lucky you. I called, talked to Tom, shipped it back. Tracking confirmed it arrived and no response. Not even a "kick rocks."
Old 06-26-2022, 03:50 PM   #11
DocRecon
DocRecon's Avatar
So your OLED doesn't work right? Mine keeps freezing up after start up. I sent it back and they said it was okay, but said the analyzer could be bad. They sent me a new analyzer along with my old OLED, but it's still doodoo.
I put the new analyzer on expecting everything to be okay, but no, it freezes as before.
Old 06-26-2022, 05:02 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, mine is dead. Lasted about a month. Everything else works fine. I honestly forgot I sent it to them and never heard anything. It was 6+ months later before I remembered so I am kind of SOL on it. I just read ethanol content through my oft now.
Old 06-27-2022, 03:58 PM   #13
DocRecon
DocRecon's Avatar
Yea, mine is tits up too and it's brand new. What da'fuq is up with that ��.
Thanks, man!
PTUNING FR-S BRZ 86 PnP Flex Fuel Kit V2 w/ FailSafe, Bluetooth 4.0, OLED Display Mrc@ptuning Engine, Exhaust, Transmission 20 05-10-2022 08:34 AM
PTUNING Flex Fuel Kit w/Bluetooth Module ptuning Engine, Exhaust, Transmission 64 01-19-2021 11:57 AM
Just ordered PTuning Flex Fuel Kit now what? Celigts Software Tuning 14 05-09-2019 05:25 PM
PTUNING FR-S BRZ 86 PnP Flex Fuel Kit V2 w/ FailSafe, Bluetooth 4.0, OLED Display Freddy@PTUNING Announcements, Contests, Giveaways 4 12-14-2017 11:37 AM
PTUNING Flex Fuel kit 15% off SALE! Freddy@PTUNING Engine, Exhaust, Bolt-Ons 3 07-29-2016 01:23 PM
