| NY / NJ / CT / PA NY, NJ, CT, PA |
Drives: 2013 scion frs 6 speed manual
frs recall regarding valve spring defect
Hey Friends/ I own a 2013 Toyota FRS 70 tho miles.
i received a recall notice regarding valve spring problem take this seriously?? thanks doug |
#2 |
ProCrastinationConsultant
many choose to disregard the recall, as some have had more problems from opening the motor than have had from the valve springs over 70k miles of use.
but without doing the recall, it's becoming significantly harder to renew the vehicle registration, or sell the vehicle, unless the recall is performed.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#3 |
WAY higher risk of the work destroying your engine than the already statistically negligible risk of a spring breaking this far into your engine's life. I have said many times here that by the time the recall was issued, all the springs that were going to break had already done so long ago. Their own internal analysis agreed perfectly with the long-understood science.
Mine is a candidate. No way is anyone touching it.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#4 |
Drives: '13 Whiteout
If you don’t need to do it to renew your registration then don’t do it
| The Following 3 Users Say Thank You to TommyW For This Useful Post: |
#5 |
Rust bucket enthusiast
Tear that shit up and keep driving, please
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#6 |
Thanks everyone. appreciate it. Going to ignore it and keep driving.
| The Following 4 Users Say Thank You to scionhobokenD For This Useful Post: |
#7 |
Purist
Drives: 2013 FRS - Hot Lava
I bought a 2013 FRS in 2016. I have put 60,000 miles on it without issue. I am passing on the recall as well. Unless I find a Toyota tech that has done a lot of them, I dont trust a random Toyota to do Subaru work.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
| The Following User Says Thank You to Westen86 For This Useful Post: | HotlavaFRSGT86 (03-30-2024) |
#8 |
LOL, The service manager said his tech has done over a hundred of em. Motor went 3,000 mi later. The shop I used to rebuild it after that fiasco said everything was clogged with sealant. Doing the recall is like playing Russian Roulette.
| The Following User Says Thank You to TommyW For This Useful Post: | soundman98 (04-29-2022) |
#9 | |
Drives: SWP BRZ
#10 |
NJDGAF
#11 |
Drives: 2013 Subaru BRZ
I was questioning having the valve recall done but decided to on the basis purely of resale. Despite the engine apparently running perfectly Subaru found a failing rocker arm during the recall work. Required a new head and valves as some were slightly bent. Anyhow Subaru covered the entire work under 'goodwill'. This is despite me never buying a new Subaru and a patchy service history on the brz. For a car that's almost a decade old I was floored with the service.
| The Following 3 Users Say Thank You to clio For This Useful Post: |
#12 |
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Yea I got one today. Screw that noise. When I bought mine last year, had 60k on it. I contemplated taking it in, but then I asked the question here, and got my answer. If you car has made it this far, and had no issues, do not do the recall. More bad has come than good with this ordeal. Unless you have a BRZ, then atleast you will have Subaru mechanics working on you motor. But do not let Toyota touch it. From what I have heard, if you do the recall and you motor fails, you will have a big fight on your hands when you try to get Toyota to replace your motor. I’ve read through all the horror stories here.
I’d rather my engine blow up because I boosted it and from my own driving and my own decisions than have it blow and it be because I chose to let some Toyota techs not put any sealant or too much or the wrong kind while replacing the valve springs. I will say, the first month, I was a little nervous every time I got in the highway, always thinking they would fail at the wrong time. But a year later, never have had a single mechanical issue (knock on wood) and I’m happy with my decision. If it happens, it happens. But it probably won’t. Most of the cars that were gonna fail, have already failed. Good luck out there. |
| The Following User Says Thank You to Sur For This Useful Post: | Ultramaroon (05-01-2022) |
#13 |
Drives: 2013 FR-S, 2007 Acura TL 5AT
I got mine done about 30k miles ago, BUT I was one of the first in my area to get my car into that Toyota dealership in late 2018. Thankfully the tech that did mine wasn't a total moron. 10+ track days later I'm still solid. HOWEVER, knowing what I know about how many of these engines died shortly after the recall I wouldn't go through with the recall again. Not worth the risk, though I did get a lot of new gaskets out of it and spark plug job free of charge.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build YouTube: Angel Christov |
| The Following User Says Thank You to AngelGT86Racer For This Useful Post: | soundman98 (05-02-2022) |
#14 | |
I agree though, if I was just getting to this now after 10 years, and almost 200K miles, I'd not do it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
| Tags |
| frs, recall, valve springs |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 05:24 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
