Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 04-28-2022, 09:56 PM   #1
scionhobokenD
Drives: 2013 scion frs 6 speed manual
frs recall regarding valve spring defect
Hey Friends/ I own a 2013 Toyota FRS 70 tho miles.
i received a recall notice regarding valve spring problem
take this seriously??
thanks
doug
scionhobokenD is offline   Reply With Quote
Old 04-28-2022, 10:19 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
many choose to disregard the recall, as some have had more problems from opening the motor than have had from the valve springs over 70k miles of use.
but without doing the recall, it's becoming significantly harder to renew the vehicle registration, or sell the vehicle, unless the recall is performed.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
DarkPira7e (04-29-2022), scionhobokenD (04-29-2022), Ultramaroon (04-29-2022)
Old 04-29-2022, 12:33 AM   #3
WAY higher risk of the work destroying your engine than the already statistically negligible risk of a spring breaking this far into your engine's life. I have said many times here that by the time the recall was issued, all the springs that were going to break had already done so long ago. Their own internal analysis agreed perfectly with the long-understood science.
Mine is a candidate. No way is anyone touching it.
DarkPira7e (04-29-2022), scionhobokenD (04-29-2022), soundman98 (04-30-2022)
Old 04-29-2022, 11:21 AM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
If you don’t need to do it to renew your registration then don’t do it
TommyW is offline   Reply With Quote
The Following 3 Users Say Thank You to TommyW For This Useful Post:
Old 04-29-2022, 12:52 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Tear that shit up and keep driving, please
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
scionhobokenD (04-29-2022), soundman98 (04-30-2022), Ultramaroon (04-29-2022)
Old 04-29-2022, 01:28 PM   #6
scionhobokenD
Thanks everyone. appreciate it. Going to ignore it and keep driving.
The Following 4 Users Say Thank You to scionhobokenD For This Useful Post:
DarkPira7e (04-29-2022), tobin (04-30-2022), TommyW (04-29-2022), Ultramaroon (04-29-2022)
Old 04-29-2022, 05:57 PM   #7
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
I bought a 2013 FRS in 2016. I have put 60,000 miles on it without issue. I am passing on the recall as well. Unless I find a Toyota tech that has done a lot of them, I dont trust a random Toyota to do Subaru work.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following User Says Thank You to Westen86 For This Useful Post:
HotlavaFRSGT86 (03-30-2024)
Old 04-29-2022, 06:11 PM   #8
TommyW
TommyW's Avatar
LOL, The service manager said his tech has done over a hundred of em. Motor went 3,000 mi later. The shop I used to rebuild it after that fiasco said everything was clogged with sealant. Doing the recall is like playing Russian Roulette.
The Following User Says Thank You to TommyW For This Useful Post:
Old 04-29-2022, 08:39 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
OP is in NJ so doesnt matter
Old 04-29-2022, 08:47 PM   #10
NJDGAF
Old 05-01-2022, 07:41 PM   #11
clio
Drives: 2013 Subaru BRZ
I was questioning having the valve recall done but decided to on the basis purely of resale. Despite the engine apparently running perfectly Subaru found a failing rocker arm during the recall work. Required a new head and valves as some were slightly bent. Anyhow Subaru covered the entire work under 'goodwill'. This is despite me never buying a new Subaru and a patchy service history on the brz. For a car that's almost a decade old I was floored with the service.
clio is offline   Reply With Quote
The Following 3 Users Say Thank You to clio For This Useful Post:
bcj (05-03-2022), Dzmitry (05-11-2022), soundman98 (05-01-2022)
Old 05-01-2022, 09:11 PM   #12
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Yea I got one today. Screw that noise. When I bought mine last year, had 60k on it. I contemplated taking it in, but then I asked the question here, and got my answer. If you car has made it this far, and had no issues, do not do the recall. More bad has come than good with this ordeal. Unless you have a BRZ, then atleast you will have Subaru mechanics working on you motor. But do not let Toyota touch it. From what I have heard, if you do the recall and you motor fails, you will have a big fight on your hands when you try to get Toyota to replace your motor. I’ve read through all the horror stories here.
I’d rather my engine blow up because I boosted it and from my own driving and my own decisions than have it blow and it be because I chose to let some Toyota techs not put any sealant or too much or the wrong kind while replacing the valve springs.
I will say, the first month, I was a little nervous every time I got in the highway, always thinking they would fail at the wrong time. But a year later, never have had a single mechanical issue (knock on wood) and I’m happy with my decision.
If it happens, it happens. But it probably won’t. Most of the cars that were gonna fail, have already failed.
Good luck out there.
Sur is offline   Reply With Quote
The Following User Says Thank You to Sur For This Useful Post:
Ultramaroon (05-01-2022)
Old 05-02-2022, 02:33 AM   #13
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
I got mine done about 30k miles ago, BUT I was one of the first in my area to get my car into that Toyota dealership in late 2018. Thankfully the tech that did mine wasn't a total moron. 10+ track days later I'm still solid. HOWEVER, knowing what I know about how many of these engines died shortly after the recall I wouldn't go through with the recall again. Not worth the risk, though I did get a lot of new gaskets out of it and spark plug job free of charge.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
The Following User Says Thank You to AngelGT86Racer For This Useful Post:
soundman98 (05-02-2022)
Old 05-02-2022, 10:32 AM   #14
Originally Posted by Sur View Post
Unless you have a BRZ, then atleast you will have Subaru mechanics working on you motor. But do not let Toyota touch it.....
Not really true. The FA20 has a unique configuration and Toyota has done way more of the recalls than Subaru (they sold almost 3 to1 Toyota in 2013). I did have mine done, and it has almost 100K miles on it since the recall. There were some that had issues, but no one has been able to say what percentage did, and of those that did most were corrected by the dealer that caused the issue without drama.
I agree though, if I was just getting to this now after 10 years, and almost 200K miles, I'd not do it.
bcj (05-03-2022), Dzmitry (05-11-2022), soundman98 (05-02-2022)
frs, recall, valve springs
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 08:03 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 06:24 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
