Old 04-11-2022, 05:25 PM   #15
sds
Drives: '22 BRZ Limited 6MT
Originally Posted by Edkwok99 View Post
Yes. I know how to turn everything off.
But I am not ready yet
If you're not ready yet, don't drive on RT660s.
sds is offline   Reply With Quote
The Following User Says Thank You to sds For This Useful Post:
timurrrr (04-11-2022)
Old 04-11-2022, 05:32 PM   #16
staples323
staples323's Avatar
Drives: '22 GR86
All good, I misunderstood. the vsc in track mode is probably still activating causing a bit more heat than usual in the brakes. The crazing doesn't look bad. Pad material seems to be glazing the disc a little bit from the excess heat though, I'm not entirely sure without seeing the pads.
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD
staples323 is offline   Reply With Quote
Old 04-11-2022, 05:46 PM   #17
Edkwok99
Drives: GR86
No worry. You are right. I need to turn everything off and experience the full dynamics of the car.
Edkwok99 is offline   Reply With Quote
Old 04-11-2022, 05:48 PM   #18
dsc_pat
Drives: Too fast
looks fine
did you engage a lot of the abs ?
dsc_pat is offline   Reply With Quote
Old 04-11-2022, 05:51 PM   #19
staples323
staples323's Avatar
Drives: '22 GR86
Originally Posted by dsc_pat View Post
looks fine
dsc_pat makes a good point too, if you're getting into abs a lot.
Old 04-11-2022, 06:07 PM   #20
Edkwok99
Drives: GR86
I don’t think so. I had not seen ABS light flashing on dashboard at track. I also didn’t feel the front tire not griping during hard brake.
I don’t think I used the full capacity of the brake. I think it is the repeated medium braking instead of multiple hard braking.
Old 04-11-2022, 07:23 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Normal from heating and cooling cycles. When they get to the edge or you can catch your fingernail on them, time to replace. You should see the pictures @CSG Mike has posted of ones he has used
soundman98 (04-11-2022)
Old 04-12-2022, 11:14 AM   #22
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
So now you know your brakes are normal for what you`re doing and probably don`t need replacing yet. Get a driver mod (Best bang for buck)
Old 04-12-2022, 10:48 PM   #23
CSG Mike
CSG Mike's Avatar
Thanks for all feedbacks.
Does that mean the pad is too aggressive for the rotor? Or/and the rotor exceeded operating temperature?
If I upgrade to a better performance rotor, will the rotor have heat checking again from track use?
You've badly overheated your pads. (the uneven streaking)
Step up to a higher capacity pad, and also, make sure you're not using ABS.
I've seen many folks who swear up and down they're not using ABS, and then when we (finally) look at the data, they're basically standing on ABS every braking zone.
Old 04-12-2022, 10:48 PM   #24
CSG Mike
CSG Mike's Avatar
ABS engagement doesn't flash an ABS light.
If you have an ABS light, your ABS system has faulted or failed, and you will get lockup.
Edkwok99 (04-13-2022), Tcoat (04-13-2022)
Old 04-13-2022, 12:28 AM   #25
soundman98
ProCrastinationConsultant
soundman98's Avatar
Lol, My phones news feed directed me to the same thread with the same pictures on the gr86 forums.
Similar result, without the ABS talk, or csgmikes insight!
Tcoat (04-13-2022)
Old 04-13-2022, 01:43 AM   #26
Edkwok99
Drives: GR86
I didn’t feel any brake fade at all. Brake pedal was firm all day.
Old 04-13-2022, 10:07 AM   #27
Spektyr
Drives: GR86
Another thing to keep in mind: the car actually measures how quickly you go from the throttle to the brake, and how quickly you press the brake down.
Quick/aggressive/panicked transition to brakes, especially with quick application of the brakes amplifies the response of the braking system. The idea is that if you're driving and suddenly need to hit the brakes to avoid an accident the car will apply the brakes harder/faster that way.
The result is you go right to ABS levels of braking.
I had a situation where I was alongside a car at 75mph on the highway approaching construction. Traffic in her lane was stopped, mine was open, and we reached the point where it became apparent she wasn't paying any attention at all. I braked "moderately" and shifted to the left shoulder to give her room to escape the impact via the left lane and the car basically stood on its nose to stop. (She never touched the brakes or noticed the car she slammed into.)
The aggro braking system pulled us up about 10-15 feet short of the debris field.
But on a race track you're going to want the ABS turned off.
Spektyr is offline   Reply With Quote
The Following User Says Thank You to Spektyr For This Useful Post:
Old 04-13-2022, 10:34 AM   #28
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
How cheap are GR86 rotors? In my experience cryo-treated rotors are usually a good bit more expensive. In many cases it's just cheaper to toss your rotors and replace.
Brake pads to swap between for DD and Track Days jim985 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-25-2020 08:12 PM
Brake compound for Track Days fer3d Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-31-2018 08:47 AM
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 03:59 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 06:42 PM
