Old 04-10-2022, 09:40 PM   #85
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
I believe they are the B6. The photo is from an earlier post from RCE.
Sent from my SM-G781U using Tapatalk
Daily86 is offline   Reply With Quote
Old 04-11-2022, 01:48 AM   #86
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Originally Posted by Daily86 View Post
I'm noticing the difference in the spring perch heights.
I noticed this as well(in the picture) and I don't care for that. Thats changing the spring preload.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 04-11-2022, 05:58 AM   #87
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Does that change once the car is sitting on its own weight and the springs are compressed holding the vehicle up
Old 04-11-2022, 08:07 AM   #88
ZDan
ZDan's Avatar
Drives: '23 BRZ
Hmm, going from stock PP/Sachs to B8s didn't change ride height on Swift springs for me at all. 12 7/8" all around before and after.
Old 04-11-2022, 10:21 AM   #89
Racecomp Engineering
It's not a good picture y'all, I wouldn't read too much into it. I'll take a better one of the rears vs stock later this week.
- Andrew
bcj (04-11-2022), JIM THEO (04-13-2022)
Old 04-11-2022, 10:25 AM   #90
Daily86
Daily86's Avatar
Can we compare the B8s also?
Old 04-11-2022, 10:37 AM   #91
We don't have those in stock unfortunately.
- Andrew
Old 04-15-2022, 03:32 PM   #92
JIM THEO
Drives: BRZ 2018
- Andrew
Waiting Andrew, as I understand B6 with lowering springs is better choice than the B8 as they have more suspension travel
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Thefalls (04-20-2022)
Old 05-16-2022, 02:51 AM   #93
Daily86
Daily86's Avatar
- Andrew
Andrew, I'm sure you're busy. Just wondering if you can try to take more pictures.
Thanks!
Old 05-16-2022, 04:01 PM   #94
norcalpb
norcalpb's Avatar
Hey Andrew, I’ve had my B6s for 80k miles and a shop told me that the front struts have play, as in the shaft can move relative to its housing. They told me Bilstein’s have bushings that support the shaft and mine are worn. Is it true these bushings exist? I also went to inspect the struts and they both have huge 4”x4” burn marks on the shafts themselves. Luckily the marks don’t have any depth like scoring would leave.
Reason I ask is because the struts aren’t making any noise but do feel “soft”. Both struts are bone dry.
The Following User Says Thank You to norcalpb For This Useful Post:
bhmax (05-16-2022)
Old 05-18-2022, 04:18 AM   #95
itschris
Drives: '14
They do exist. When my dad sent in his B8s to be rebuilt for another platform they replaced them. I'm surprised you don't hear knocking if they're that bad.
I think this part number might work, but really I'd just have someone refresh everything. Probably not easy for normal people to get.
P/N: E4-LB1-Z008A09 BUSHING: 36MM UMS INTERNAL HSG
I attached a pic from Bilstein's website with a cutaway, it seems relevant to this thread.
Always learning.
itschris is offline   Reply With Quote
The Following 2 Users Say Thank You to itschris For This Useful Post:
norcalpb (05-18-2022), Racecomp Engineering (05-18-2022)
Old 05-18-2022, 10:36 AM   #96
Thanks!
Crap, sorry. My extra set of rears is with a friend at the moment. Soon though!
By "shaft" do you mean the part you can see or the shaft inside the strut body?
https://www.instagram.com/p/CbumUe_r...d=YmMyMTA2M2Y=
Either way, yes there are bushings/bearings and the rod guide that can wear out and cause some of the marks your seeing. No noise is a good sign, but 80k miles is a very solid run and I would start planning on sending them in for a rebuild.
- Andrew
Daily86 (05-18-2022), norcalpb (05-18-2022)
Old 05-18-2022, 05:17 PM   #97
norcalpb
norcalpb's Avatar
- Andrew
Hi Andrew,
Yes by shaft I mean the part that you can actually see. I guess since it's inverted, the actual shaft is inside the body duh!
I'm thinking about just replacing them as I've stripped the upper allen shaped holes bad enough that I'm forced to imperial sized allen wrenches to loosen/tighten the nut without spinning the shaft and I don't think a rebuild will be able to fix that right? Sucks they are $250/side now...but at least my rear B6s are holding up well.
Racecomp Engineering (05-19-2022)
Old 05-19-2022, 10:22 AM   #98
Hi Andrew,
If you send them in, they could replace that part...but you might be getting close to the cost of a new one anyway. I'm not sure. It's worth a call to them.
Should also think about the B6s going in and out of stock and the occasional long wait though.
- Andrew
norcalpb (05-19-2022)
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 12:22 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 01:50 PM
Ok, who has stories that can't be explained? husker741 Off-Topic Lounge [WARNING: NO POLITICS] 143 11-26-2014 06:25 AM
Part of the problem explained. Suberman CANADA 95 01-28-2014 02:26 PM
