Old 04-02-2022, 11:59 PM   #113
ka-t_240
Not sure I have seen this topic discussed here, what is the formality on coil packs? I have 1, possibly 2 that are on the way out. Started getting codes at my last track day. Figure I am going to replace plugs and all 4 coil packs in the coming month.
I see many people supposedly having better reliability with non OEM packs on the earlier model cars, or are swapping engine harness and coils to the 2015+ cars(don't want to swap the engine harness), so thinking of the aftermarket coils discussed in other posts here like the IP ones.
ka-t_240 is offline   Reply With Quote
Old 04-03-2022, 03:29 AM   #114
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Oem or oem equivalent only is how I read the rules. Given their marketing material the IP definitely brand themselves as a better design.
The IP Coils produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process.
ineedyourdiddly
Old 04-04-2022, 01:33 PM   #115
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Are most of you guys using adjustable rear endlinks? My front endlinks are SPL adjustable, but rears are still stock. Wasn't sure how much difference it would really make to remove preload from the rear bar.
smg1138 is offline   Reply With Quote
Old 04-04-2022, 03:15 PM   #116
Autoxer62
Per 13.9.A (Street Category):
The make of spark plugs, points, ignition coil and high tension wires is unrestricted including spark plug wires having an in-line capacitor. Substitution or addition of ignition coil mounting brackets is permitted, provided they affix to the original standard location and serve no other purpose. (Modification of the distributor cap for the purpose of installing allowed non-standard components is not permitted.)
Looks like aftermarket coils are ok.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 04-05-2022, 11:27 AM   #117
e1_griego
e1_griego's Avatar
Drives: Many
Yeah I thought aftermarket were fine -- I nuked a coilpack in fontana last year (the traction control turn on/off 3 times on my final run as the CEL came on) and sort of kicked myself for putting new oems back in because I hadn't read the rulebook to see if I could do aftermarket. Oh well.
e1_griego is online now   Reply With Quote
Old 04-05-2022, 11:38 AM   #118
ka-t_240
That was my assumption - but since someone will always say something based on a companies marketing of them being "better than oem", and that they have red on them, wanting to dot my i and cross my t before making plans / spending money.
I will have to see what my price on on OEM coils too before moving along too far.
Old 04-05-2022, 04:42 PM   #119
renfield90
The Stig's German cousin
Remember, it's the heat that kills them. I'd be more interested in what the aftermarket coils are doing for reliability than any improvements in spark.
Also, I wrapped my header in 2017 or 2018 (I forget) and promptly stopped killing coils. It's not foolproof, we killed a coil on Kate's old car last year despite the wrap on her header, but I'm sure we would've killed more.
IMO a ceramic coat isn't enough. The OEM header has a heatshield for a reason.
Old 04-05-2022, 04:46 PM   #120
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Did you wrap the entire header or just the area under the coils?
Old 04-05-2022, 05:00 PM   #121
ka-t_240
I have the stock over pipe still, so possibly why its taken a long time before I started having failures? I have only replaced 1 so far. Thinking its time to do plugs this spring, so figured I would just do them while they are out.
I also have a second hood which is on my car 99% of the time which is vented. Car sees a fair bit of track time so venting was something I did long ago, especially since the local track has a lot of upper 5th gear time.
Old 04-05-2022, 11:09 PM   #122
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I killed a couple coil packs at Cota in July last year. On the new ones I wrapped them in this stuff. It works pretty well on the heat reduction so far: https://hhrperformance.com/i-3163686...=brand:159796#
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 04-06-2022, 12:17 AM   #123
renfield90
The whole header. Might as well do it right and get the full benefit - the less excess heat in the engine bay the better.
In theory this also keeps the exhaust gases hotter, which helps them flow faster.
The Following User Says Thank You to renfield90 For This Useful Post:
DocWalt (04-06-2022)
Old 04-06-2022, 12:21 AM   #124
renfield90
Nah, it's just dumb luck. These OG spec coil packs are just fragile.
For me, I killed my first coil within 6 months of installing the header (and I kept the stock overpipe same as you). A few months later, killed another. My hands are big enough to make this job unpleasant so I broke down and wrapped the header.
Old 04-06-2022, 10:31 AM   #125
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I asked because JDL says to not wrap the whole header (not sure why) and I'd like to avoid issues down the road. I wrapped the OEM header on my RX-8 without issue so I guess it's fine
Old 04-06-2022, 12:18 PM   #126
renfield90
Huh, I wasn't aware and I've got a JDL UEL. Like I said, it's been close to half a decade at this point.
Admittedly I stick to autocross, and maybe run one track day a year, but I'm also running in hotter weather than 95% of you.
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 02:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
