Old 04-01-2022, 03:41 AM   #1
voribis
Drives: FT86
Header Question
Anyone gone from a r400 to a q300, then got a uel? I had an r400 swapped to a q300 due to the drone at highway speeds and on hills.
q300 is fine by itself but want to add a psr uel & overpipe and leave front pipe stock. From what I've read drone shouldn't be an issue with this setup, any feedback appreciated. thanks!
voribis is offline   Reply With Quote
Old 04-01-2022, 06:03 PM   #2
norcalpb
norcalpb's Avatar
I think it should be fine, but what others have noted is that the q300 muffler packing can disintegrate over time leaving you with a loud exhaust setup.
Old 04-11-2022, 01:25 AM   #3
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
I recently put in a header and overpipe, with STOCK exhaust from there back. its louder than stock by a good amount. I might try that if I were you. Before you try anything with more volume, at least
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 04-11-2022, 05:12 PM   #4
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I had the UEL headers, then the R400 exhaust, then the Q300 exhaust and then added a catless resonated frontpipe. The last thing I did was use two STI hangers for the rear two hangers. There's no drone when cruising on the highway - mostly just the typical tire noise and NVH. It's almost stock level. When you floor it, it gets loud.
kevaughan is offline   Reply With Quote
Header Question frickenchick Engine, Exhaust, Transmission 4 09-11-2021 09:16 PM
JDL Header Question Swolzee Engine, Exhaust, Transmission 5 05-20-2021 01:17 AM
Header on N/A question FR-Shred Engine, Exhaust, Transmission 4 06-19-2015 07:47 AM
UEL Header question iarefluffy Engine, Exhaust, Transmission 12 01-26-2015 12:16 AM
Header question ft86me Engine, Exhaust, Transmission 18 03-14-2013 12:38 AM
