go_a_way1
Old 02-22-2022, 09:54 PM   #4439
NJ-JDM
Drives: 2013 BRZ Limited
Does anyone run staggered tire sizes on a square wheel set? For handling? For looks? Found a deal on a set of new tires and was just going to grab them for the rears (245/35/18). But thought about running the 225/40/18 up front.
Thanks
Wheels 18x8.5” square et44
Tires F-225/40r18 R-245/35r18
2013 BRZ Limited
NJ-JDM is offline   Reply With Quote
Old 03-20-2022, 08:32 AM   #4440
Mtl135i
Drives: BMW 135i
18x8.5 et 30
How much of an issue would these be with 245 40 18. Listed on the tirerack as a fit but I have serious doubts.
Factory suspension camber bolts and -1.5 camber up front.
2019 BRZ with the brembo brakes.
Search revealed one with the same specs and it poked quite a bit.
Thanks
Mtl135i is offline   Reply With Quote
Old 03-21-2022, 10:25 AM   #4441
Vital
Drives: 2015 BRZ
Thanks
What suspension are you planning on using? Stock or coilovers, springs...? If you plan on using Coilovers yes it will fit. That is a pretty low offset and will push the wheel out so if you do have rubbing it will be on the fenders. But if you use camber bolts that will help tuck the wheel in.
The Following User Says Thank You to Vital For This Useful Post:
Mtl135i (03-21-2022)
Old 03-21-2022, 01:30 PM   #4442
Mtl135i
Drives: BMW 135i
Planning on stock for now. Thanks. Will maybe roll the dice and order them
Old 03-21-2022, 06:47 PM   #4443
Vital
Drives: 2015 BRZ
Oh yeah that will fit stock, but yes you will have a lot of poke. Id wait till you drop the car a bit or get wheels with a less aggressive offset .
Old 03-21-2022, 09:06 PM   #4444
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Why 245/40? 245/35 is near identical to stock rolling diam….
ACT86 is offline   Reply With Quote
Old 03-23-2022, 02:55 PM   #4445
oBradyG
Drives: 2020 Subaru BRZ AT
Hi guys wondering if 18 x 10.5 + 22 all around with 255/35 front and 265/35 rear will fit flush? I know u must run spacers with this setup, but does anyone know how big of spacers?
He is running this exact setup but I don’t know how big of spacers he uses https://ibb.co/9bZZY5f
oBradyG is offline   Reply With Quote
Old 03-26-2022, 12:58 PM   #4446
Newbee
After going through these pages I’ve learned a lot!!!
I am currently on stock suspension with no modifications on my 13 BRZ.
Just bought some Option Labs R716 18x9.5 +35 offset.
Looking to run them on 255/35/18 Firehawks Indy 500
Will these fit on stock suspension? After reading I know 38 offset will rub strut, but hopeful I’ll be ok with 35 offset
Newbee is offline   Reply With Quote
Old 03-28-2022, 10:39 PM   #4447
Vital
Drives: 2015 BRZ
Yes they will fit on stock suspension, but its gonna be really close in the front. Also, you should probably get some coilovers and lower it those wheels are gonna poke with stock suspension and wont look good, but to each their own.
Old 04-01-2022, 12:11 AM   #4448
Newbee
Yes they will fit on stuck suspension, but its gonna be really close in the front. Also, you should probably get some coilovers and lower it those wheels are gonna poke with stock suspension and wont look good, but to each their own.
Thanks for letting me know, lowering the car will be my next project but for now this all I can afford. Maybe in 3-4 months.
Old 04-01-2022, 12:00 PM   #4449
Vital
Drives: 2015 BRZ
Sure np, if you do end up getting that wheel and tire spec. id just going with coilovers so you dont have to worry about clearance issues, just fyi.
Old 04-19-2022, 03:34 AM   #4450
Aus
Drives: 2014 Toyota 86 GTS
going crazy reading hundreds of posts, so thought would ask here.
Looking at Rota Titan R's in Matt Bronze. In Australia, these only come in 17x9 +38
Car will be on stock suspension, might later on go with TRD lowering springs at most. No plans for coil overs/camber etc
First question is, will these sit flush, and then whats the best size tires to make sure no clearance issues and no negative impact on drivability. Both on stock suspension and if i go with lowering springs down the line?
Or Rota also do the Titan F here in a 17x8 +42. Is that a better size?
Only difference between Titan F and R from what i can gather is more aggressive spoke angle on the R and different sizes
Aus is offline   Reply With Quote
Old 04-19-2022, 10:17 AM   #4451
Vital
Drives: 2015 BRZ
17x9 +38 will fit just fine on stock suspension and lowering springs. Yes it will be just about flush if you lower the car 1" with the TRD springs. If you dont get that lowering springs then that will poke a bit. The tires you can use are 245/40/17. If you dont plan on lowering the car then 17x8 +42 might be a better choice.
Old 04-20-2022, 07:51 PM   #4452
Aus
awesome, thanks
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
