Old 03-11-2022, 07:57 PM   #1
Liquidsnake
Drives: "I drives like a Porsche"
Spring valve exhaust options?
Spring valve exhaust options? Are there any exhausts that are spring loaded in which the valve opens under pressure or when you hit the accelerator? I’m looking for an exhaust where the valves open under load. Any options out there?
Liquidsnake is offline   Reply With Quote
Old 03-11-2022, 10:01 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
yes
Old 03-11-2022, 10:51 PM   #3
Dake
Dake's Avatar
/thread closed
Dake is offline   Reply With Quote
Old 03-11-2022, 11:46 PM   #4
Liquidsnake
Any names? Who makes exhausts like that?
Old 03-12-2022, 11:33 AM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I've seen the ones that work with gravity.
May be able to retrofit a spring.
Ultramaroon (03-14-2022)
Old 03-12-2022, 11:39 AM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
John Deere?
Old 03-12-2022, 02:33 PM   #7
Liquidsnake
Am I missing something? Why is everyone making jokes?
I have 124 Abarth with the Record Monza Exhaust that opens and closes under pressure. I absolutely love the way it sounds, It has zero drone.
With an 86 on order, I was looking for something similar where its not loud or droning on the freeway but when you punch it its very nice.
If I am explaining things in a rudimentary or silly way I apologize, I am not sure where the jokes come from, or what they are referencing. Just wanted some advice.
Im only looking for Axelback.
Old 03-12-2022, 03:27 PM   #8
Dake
Dake's Avatar
Two reasons: 1, it's the internet and B, you can search this very website to find similar questions and answers.
The short answer is "yes"
The slightly longer answer is "Yes, you can add a bypass into your existing exhaust or most any after market exhaust that works either mechanically or electronically. People have been doing it to their cars for decades."
I don't think a ton of people here have done it though because in the end we're still talking about a four cylinder motor. Going straight-pipe is going to mostly sound obnoxious and will offer very little performance gain.
The Following User Says Thank You to Dake For This Useful Post:
x808drifter (03-13-2022)
Old 03-12-2022, 04:04 PM   #9
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Depending upon the noise ordinances in your particular jurisdiction you may also be rewarded with a fine courtesy of the local constabulary.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
Old 03-13-2022, 12:34 PM   #10
bcj
Geo Tyrebighter Esq
bcj's Avatar
Terminology is what got me I guess.
Waaaay back in teh day it used to be called exhaust cut outs and they were usually flat plates you could unbolt once you got to the dragstrip or dry lake so you wouldn't be arrested on your way there.
The new ones mostly seem to be electronically controlled for ON / OFF.
Hadn't heard of spring controllers like a turbo blow off for exhaust. Hadn't been following Abarth.
I suppose with a semi-weedy small displacement engine it would work sort of.
An extremely stroked big block could be annoying at anything above idle. Probably even worse warming it up in the garage.
Old 03-13-2022, 04:57 PM   #11
Liquidsnake
If you read the description it talks about a spring loaded diversion Valve. This is the best exhaust I’ve ever had in my life and I was just looking to replicate it with a GR 86 https://www.moparonlineparts.com/sku/82215590.html
Old 03-14-2022, 11:58 AM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Looks fairly simple. get a Mr. Gasket cutoff and replace the cable with a BOV spring of whatever weight pleases you most.
Size:  34.4 KB Name:  bov2.jpg
Valve Spring Re-call Fast13FRS Issues | Warranty | Recalls / TSB 81 04-12-2020 12:36 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 10:55 PM
valve spring procedures ric342 Southern California 3 03-21-2019 08:46 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
