Old 04-11-2021, 06:56 PM   #57
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by Capt Spaulding View Post
@RToyo86:
Might I ask a favor or two. First, what sized tires/wheels are you running? Second, could you take and post another image taken from the side, with the lens at door handle height or top of tire height?
Many thanks,
Sure no problem.
I am on the stock primacy wheel tire setup while waiting to install new rubber on other wheels.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Capt Spaulding (04-12-2021), Thefalls (04-12-2021)
Old 04-12-2021, 08:18 AM   #58
Thefalls
Thefalls's Avatar
Drives: Corolla GT
@RToyo86:
Many thanks,
You have echoed my thoughts nicely.
Thefalls is offline   Reply With Quote
Old 04-12-2021, 03:33 PM   #59
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
@RToyo86
That, my friend, was perfect. Thanks a million.
PS: I rather like the look of those wheels.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-12-2021, 03:53 PM   #60
RToyo86
RToyo86's Avatar
@RToyo86
The stock 2017 wheels clean up pretty well.
I find it helps with back wheel nuts and calipers.
Old 03-08-2022, 04:37 AM   #61
JIM THEO
Drives: BRZ 2018
I bring back this old thread just to ask again if someone has experience with the B6 and the OEM tS >18 springs
JIM THEO is offline   Reply With Quote
Old 03-10-2022, 03:09 PM   #62
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I'm running this combo on my 2019 BRZ PP and I freakin love it.
Body control is far superior to the stock springs and Sachs dampers. The ride is a bit firmer (passengers will notice), but not harsh or crashy.
N_Raged is offline   Reply With Quote
The Following 2 Users Say Thank You to N_Raged For This Useful Post:
JAS4 (03-11-2022), JIM THEO (03-11-2022)
Old 03-11-2022, 07:43 AM   #63
JIM THEO
Drives: BRZ 2018
I expected it to be comfortable but never mind, thanks for your answer, you should be the only one that runs this setup, and me in the future!
By the way how much miles the standard tS Sachs withstand, I already have 50.000kms and they work fine
Old 03-11-2022, 09:09 AM   #64
churchx
churchx's Avatar
Drives: 2014 GT86
I expected it to be comfortable ..
B6 for me were slightly, but less comfortable then stock (MY2013 GT86) suspension. At least for smaller road imperfections/rougher roads. Due a bit more firmness car, as some may say, is "more composed", and on track when pushed a bit better, but i wouldn't consider them if comfort for DD is the goal.
Old 03-11-2022, 09:42 AM   #65
ZDan
ZDan's Avatar
Drives: '23 BRZ
Interesting, I've found B8s (same as B6 with less droop travel) to be way WAY more comfortable on the road vs. '17 PP/Sachs. Way less harsh over bumps and way more front bump travel, while having *slightly* more low-speed damping. If anything I'd prefer more low-speed damping to go with 5.3/4.4 kg/mm Swift Spec-R springs on my car, feels slightly underdamped to me.
CSG Mike (03-11-2022)
Old 03-11-2022, 10:22 AM   #66
Racecomp Engineering
In general I've found the Bilsteins to be a good bit more comfortable on bigger bumps and potholes. They have just slightly more compression damping, and a little less high speed rebound (depending on which year OEM we're talking about). More digressive. Plenty more rear rebound which does impact ride quality slightly but sure is helpful with aftermarket springs. Adjustable would be nice to tune that a little bit but overall they have a feel that is more reassuring (to put it one way) on the terrible roads I drive on.
Just wish they weren't always backordered.
- Andrew
Old 03-11-2022, 11:25 AM   #67
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Is there a better combination (B6 w/OEM springs, B6 w/any particular aftermarket spring, etc) that rides better than the base (non-PP) OEM setup?
I track the car a couple of times a year, but since that is just for fun, keeping the wife happy and willing to ride in the car is more important than track use. Admittedly though it is not just her as I'm getting into the old fart age range and have to admit I care about a more compliant ride than I used to!
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 03-11-2022, 02:02 PM   #68
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I don’t think you’ll find anything that rides better than the 2017-2020 base suspension. Everything else has more damping and/or higher spring rates.
The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post:
bucketfoot (03-11-2022), churchx (03-12-2022), kevaughan (04-11-2022), marco_mc22 (03-11-2022), Pat (03-11-2022)
Old 03-11-2022, 03:13 PM   #69
Pat
Pat's Avatar
Drives: 2023 BRZ
If you want to drive a bunch of different setups come over on Wednesday. I'm sure everyone would be happy to let you test their cars. But if comfort is your top priority to stick with OEM.
Old 03-12-2022, 12:10 AM   #70
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Adjustable shocks paired with springs?
The likes of KYB Extage or Cusco Touring A?
You can use lowering springs with the Cuscos ....with the KYBs I dont know yet.
But they are both adjustable for rebound.
And you still use your oem topmounts to minimize NVH.
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 12:22 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 01:50 PM
Ok, who has stories that can't be explained? husker741 Off-Topic Lounge [WARNING: NO POLITICS] 143 11-26-2014 06:25 AM
Part of the problem explained. Suberman CANADA 95 01-28-2014 02:26 PM
