| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: 2022 GR86 - Halo White
Lightweight battery options for daily driver
Anyone change out their stock battery for something lighter yet? What battery and mounting solutions have you come up with?
I slightly scrape on my driveway and am fixing this by getting taller tires and reducing battery weight. Hopefully this will be enough to stop it from happening. |
#2 |
Not sure if it will help with scraping but I replaced my battery with an anti-gravity LiFePo4 and saved like 30 lbs.
Sent from my SM-G975U using Tapatalk |
#3 |
Drives: 2018 Subaru BRZ
Say sike right now....
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | Jdmjunkie (03-01-2022), soundman98 (03-01-2022) |
#4 |
#5 | |
The cheapest and best solution would be getting curve ramps like BRIDJIT or just make a quick trip to your Lowe's / H.D and get a wood plank.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | soundman98 (03-01-2022), StE92ve (03-01-2022) |
#6 |
Meow
Drives: GT86 (now sold)
This, or just try a different angle of approach. The gen 1s are cars that scrape surprisingly little for their right height. It's likely true for gen. 2s, if you're scraping then most other non-SUV drivers are too, there's probably a way :-)
| The Following User Says Thank You to alex87f For This Useful Post: | soundman98 (03-01-2022) |
#7 | ||
Alright good idea. I ordered some rubber curve ramps and will talk to the neighbors about bolting it into the concrete so nobody else walks off with them. Hopefully the city doesn't have an issue with it. I still plan on getting a lighter battery as I have another vehicle needing a battery replacement that I'm tossing the OEM battery into. Since it's a warm climate here I'm thinking the Deka ETX-30L may be enough. Quote:
When I originally tried that it worked okayish without a passenger, but an occupant was enough to make it scrape a bit. Neighbor's porsche scrapes too as did my prior infiniti. An old friend's challenger didn't scrape, but the car got stuck going over the hump in the middle. It's a terrible easement. |
#8 |
Drives: Crapcan
Step 1-Measure ride height.
Step 2-Remove battery and spike on ground, preferably concrete or asphalt. Step 3-Measure ride height. Step 4-Realize difference is negligible.
| The Following 10 Users Say Thank You to NoHaveMSG For This Useful Post: | alex87f (03-01-2022), Jdmjunkie (03-01-2022), Ohio Enthusiast (03-01-2022), p1l0t (03-01-2022), soundman98 (03-01-2022), Spankopotomous (03-02-2022), Spuds (03-01-2022), timurrrr (03-01-2022), Wally86 (03-01-2022), x808drifter (03-02-2022) |
#9 |
Drives: X5 35d, D90, CX-5 Turbo
Not only will the lightweight battery make no difference in your ride height, today's vehicles have heavy electrical loads. Not sure I see the value in reduced battery capacity (as is likely going to be the case with a 'lightweight battery') for street use. Guessing there are many, many better ways to spend your money..
#10 |
Drives: '13 FRS - STX
I’ve had an odyssey pc680 for 3+ years now, cheaper and almost 15# lighter then stock iirc. Stock lasted a little over five years, this looks like it’ll get me too 4 no problem. No trickle charger or anything, has sat for a week and fired up no problem. Caveat my car has only rarely been below freezing temps overnight.
I used the Japanese tie downs, $30-$40 and waiting a month for shipping, if you’re crafty you could probably do it easier and better fitting, it sill looks like I have the “wrong” size battery but it’s held firmly in place. https://www.ft86club.com/forums/show....php?p=2746249 And per above your ride height change will be hundredths of an inch at best taking 10-20# off the front. |
| The Following User Says Thank You to strat61caster For This Useful Post: | NoHaveMSG (03-01-2022) |
#11 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | strat61caster (03-01-2022) |
#12 | |
#13 |
ProCrastinationConsultant
i know only weirdo's do this, anymore, but...
have you tried backing into your driveway? my rear bumper never scrapes. my front bumper does, but only at high approach speeds when i'm showing off to the neighbor kids..
#14 | |
Good idea. This would certainly work since I only scrape coming in. If the rubber ramps don't pan out I'll likely do this. |
| Best battery for daily driver | ScionFR-S | Issues | Warranty | Recalls / TSB | 132 | 01-27-2022 09:40 AM |
| SOLD: SEWI Shorai Lithium Battery and PTUNING Billet lightweight battery tray | timepoor | Audio/Visual, Electronics, Infotainment, NAV | 4 | 10-06-2021 10:40 PM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 12:07 AM |
| MAW lightweight battery kit. | Turn in Concepts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 08-24-2016 06:57 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
