#71 |
Drives: X5 35d, D90, CX-5 Turbo
| The Following 3 Users Say Thank You to LRNAD90 For This Useful Post: |
#72 |
Drives: '22 WRB
#73 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | Jdmjunkie (02-16-2022), OkieSnuffBox (02-22-2022) |
#74 | |
Drives: 2015 BRZ Series.Blue
You're right! I along with Essex, Brembo, Subaru, Porsche, *insert company here* know nothing about thermal capacity and how it relates to braking performance. oh well. back to the track with my single pot calipers |
#75 |
Good now GTFO and shut up.
| The Following User Says Thank You to weederr33 For This Useful Post: | Jdmjunkie (02-16-2022) |
#76 |
#77 |
Every Ounce Counts
Drives: 86
| The Following 3 Users Say Thank You to Lightened For This Useful Post: |
#78 |
Don't forget this: stock brakes are perfectly fine for 99% of drivers.
#79 |
Drives: 2022 GR86
#80 | |
However if you do a search for "taco" using the search function, you'll see "reputable" member posting about limitation of stock brakes including "tacoing" |
#81 |
Drives: 2022 GR86
#82 | |
Drives: Crapcan
![]() https://www.ft86club.com/forums/show...1&postcount=13
#83 |
Take that, Beotch.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | weederr33 (02-16-2022) |
#84 | |
Drives: '23 BRZ
You are arguing against points no one is making. Of course much bigger rotors with fixed 4-piston calipers and much bigger pads are going to have more thermal capacity. But the dinky base-model stock rotors and calipers, with appropriate pads and fluid, have more than enough thermal capacity for *most* people tracking these cars at HPDEs. I don't think anyone has made the argument that BBK serve no function for anyone. For sure if you are doing endurance events, or have significantly greater than stock hp, or significant downforce, you're a lot more likely to need moar brakeage! But as for actual *performance*, as in rate of deceleration, BBK isn't going to do anything for you in terms of decreasing lap times over a short stint. If brakes aren't cooked and front/rear balance is good, deceleration is a function of tire grip, period. This is my world, I run A052 tires for time trials competition, and they just aren't up to extended sessions. I got the PP Brembo BRZ for two reasons: 1) ease of pad swaps and 2) they look kick-ass. Unfortunately my club has (misguidedly!) saddled down Brembo-equipped 1st-gen FT86s with +60 lb. vs. base models :'( B.S., I'd rather have base brakes and run 60 lb. lighter... |
| The Following 4 Users Say Thank You to ZDan For This Useful Post: |
| Tags |
| big brake kit, brz, gonna happen soon, my big break, wilwood |
| FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
