Old 12-29-2021, 04:37 PM   #15
Grady
Grady's Avatar
Originally Posted by jamestemperante View Post
how long does it usually take to fully bled or let the air escape from the system? It's been more than a month since my last coolant change
I think mine did it for 6 months or more.
The Following User Says Thank You to Grady For This Useful Post:
jamestemperante (12-30-2021)
Old 12-29-2021, 05:09 PM   #16
7 skulls
Drives: 2014 scion frs
I've done 2 separate coolant changes and noticed some minor loss out of the bottle for months afterward.
7 skulls is offline   Reply With Quote
The Following User Says Thank You to 7 skulls For This Useful Post:
Old 02-14-2022, 08:36 PM   #17
jamestemperante
Drives: Subaru BRZ
hello again. just want to confirm once more, changed my radiator cap back to oem but still slowly losing coolant about 1.5mm to 2mm everytime I do a 15 to 30 mins short trips.
jamestemperante is offline   Reply With Quote
Old 02-14-2022, 09:06 PM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
If you're worried about it, slowly add coolant.
jamestemperante (02-14-2022)
Old 02-14-2022, 09:22 PM   #19
It would bother me but, like @7 skulls said, his took a long while to stabilize. As long as you don't smell it under the hood, and your oil shows no signs of contamination, I'd keep driving and watching.
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 02:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 09:37 PM
Slowly losing (and smelling) coolant PantsDants Issues | Warranty | Recalls / TSB 11 01-31-2016 10:52 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Slowly getting to where I want to be... eddieEndo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 07-21-2014 02:48 AM
