Drives: Subaru BRZ
Slowly losing coolant
Hello again everyone, I don't know if I'm just paranoid or what, I've noticed that my coolant level in the reserve tank drops about 1mm every time I drive for about 20km and let it sit and cool down for 12hrs. Is this normal to lose that amount of coolant for just a short distance trip? Thanks again for your input
AutoX-10/10ths every run
That coolant overflow tank is not sealed. Fluid may be evaporating from within the overflow tank. I would keep an eye on it to see if you notice a sudden and substantial decrease of fluid in either the overflow tank or the radiator itself before I'd start to be concerned.
not playing cards
Not paranoid. That's what happens with a slow leak in the radiator cap. Never builds full pressure. Hot spots sizzle a bit.
Drives: Subaru BRZ
Radiator cap is also new, I bought last month with a 1.3 spec on it.
Drives: Subaru BRZ
Also replaced the thermostat and did a full coolant change/flush I think more than a month ago.
not playing cards
New doesn't guarantee good. All it takes is a tiny leak in the return valve. Now I remember.
https://www.ft86club.com/forums/showthread.php?t=147467 Keep driving and watching it. If it doesn't settle down and you don't smell leaking coolant, try another OEM cap.
Drives: Subaru BRZ
are headgasket problems common to our engines?
Drives: Subaru BRZ
nah. I dont smell any kind of coolant smell inside or in the engine bay. Will keep an eye on it.
not playing cards
No, and your reservoir is completely clean. No oily shit in there. Relax.
#10 |
Drives: 2013 frs base
Could be nocturnal emissions.
#11 |
Drives: 2014 scion frs
If you did a recent coolant change as you said, then it's probably some air still escaping the system.
#12 |
Drives: Subaru BRZ
how long does it usually take to fully bled or let the air escape from the system? It's been more than a month since my last coolant change
#13 |
Drives: Crapcan
Mine always settles on the reservoir being empty after a half dozen drive cycles so I leave it. Rad's always full. DD'ing I would just check it every oil change, and check it before a track day.
#14 |
Drives: Subaru BRZ
Are you parking in the exact same spot? Pavement tolerances need to be considered when observing fluid levels..
| How is it possible to lose coolant, if the coolant system in a car is a closed loop, | ghostzfh | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-12-2020 01:09 AM |
| Coolant level dropping & Dirty coolant | redwine | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 44 | 09-30-2018 08:37 PM |
| Slowly losing (and smelling) coolant | PantsDants | Issues | Warranty | Recalls / TSB | 11 | 01-31-2016 09:52 PM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
| Slowly getting to where I want to be... | eddieEndo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 07-21-2014 01:48 AM |
