Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-03-2022, 12:28 PM   #141
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by Pat View Post
Ugh...that's a thing with the second generation cars, too? I was hoping they would have addressed that. I (okay, my friend) replaced the old anchor with a new one but it was only a temporary fix.
Does anyone have a permanent fix for this? It's annoying, especially in cold weather.
Would it be possible to do a rivnut and pan head or countersunk screw?
Old 02-03-2022, 12:32 PM   #142
groovymoonbear
groovymoonbear's Avatar
Drives: ‘22 CWP BRZ LTD 6MT
I was just thinking of finding a way to pop it out and throw some 3M tape back there until it was fully padded to prevent squeaking.
Are there third party dead-pedals out there?
groovymoonbear is offline   Reply With Quote
Old 02-03-2022, 12:35 PM   #143
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I peeled it back on my first gen and put felt tape on the underside of the foam. Stopped the squeaking.
The Following User Says Thank You to DocWalt For This Useful Post:
Midnightsky (02-03-2022)
Old 02-03-2022, 02:22 PM   #144
Sasquachulator
Pavement Grey
Originally Posted by Midnightsky View Post
Alright, so I finally had a chance to experience the turn signals on a 22 BRZ........what an odd choice by Subaru, certainly will take some getting used to. Is this something other manufacturers are starting to do now?
BMW was the first to use that style several years ago, and a bunch of other manufacturers slowly followed soon after.
But BMW are now going back to the turn signals that actually stay in position again lol.
Old 02-03-2022, 07:54 PM   #145
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
I am pretty much used to it now, it's still strange but ultimately it works
Midnightsky is offline   Reply With Quote
Old 02-04-2022, 10:37 AM   #146
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Maybe seeing early signs of the hyperflashing issue, occasionally when I start my turn signal it'll hyper flash once then go to normal flashing
Happens maybe 20-30% of the time
suhhh is offline   Reply With Quote
The Following User Says Thank You to suhhh For This Useful Post:
beat1 (02-04-2022)
Old 02-04-2022, 11:23 AM   #147
Sasquachulator
Pavement Grey
Its just one of those "why?" things that car manufacturers like to do...make a simple function more complicated than it needs to be.
Just like gearshifters in automatic equipped cars....
Used to be just your traditional gated shifter, but now theres electric rotary knobs, buttons, and the joystick things that you use to shift into gear......
Old 02-04-2022, 11:40 AM   #148
Whenever I drive the work truck I reach for the nonexistent shift lever.
EVERY SINGLE SHIFT
alone1i (02-14-2022), Jegan_V (02-04-2022)
Old 02-04-2022, 12:09 PM   #149
Jegan_V
Drives: 2023 Subaru BRZ
EVERY SINGLE SHIFT
Done that a few times myself.
Worst with this particular one is when you're transferring drivers and the driver forgot to put it in Park and actually get out because it's on a very slight grade and didn't notice it very slowly moving.
Sent from my Pixel 6 using Tapatalk
Jegan_V is offline   Reply With Quote
The Following User Says Thank You to Jegan_V For This Useful Post:
Tcoat (02-04-2022)
Old 02-04-2022, 12:39 PM   #150
gogyo
Drives: 2022 GR86 Premium MT
Originally Posted by azndavepgh View Post
There was at least one day where my right turn signal would flash quickly like it had a bad bulb, but then it started working after a few seconds. Now both sides flash quickly very briefly before working.
me as well on the gr86
gogyo is offline   Reply With Quote
Old 02-04-2022, 01:27 PM   #151
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I talked about this before, and finally got off my lazy bum to get a video of it.
My seat belt clip area is loud AF. If I move at all (leaning forward, looking left, hitting a bump in the road, etc.) I get this lovely sound.
Happening to anyone else. Dealer said its "normal." so I'm already having to go to corporate to whine about it. It's not the nut holding the belt clip on, its whatever is used for the angling of the driver side belt clip.
Bonus clip too, my blinker issue:
SpectreRT is offline   Reply With Quote
Old 02-04-2022, 01:32 PM   #152
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
The new turn signals are mechanically simpler then the locking ones, this is the car manufacturer making a simple function more simple, not more complicated.
Interceptor777 is offline   Reply With Quote
The Following User Says Thank You to Interceptor777 For This Useful Post:
timurrrr (02-04-2022)
Old 02-04-2022, 01:45 PM   #153
groovymoonbear
That seat belt noise would drive me CRAZY. Praying I don’t run into the same issue. Wonder what it is - I definitely take up a lot of space and put some good pressure on mine but I’ve never heard it squeak like that.
Wonder if you take it to a dealer if they can replace it or something, if mine isn’t doing it and few of yours are maybe some dude on the production line did something goofy accidentally
Old 02-05-2022, 03:51 PM   #154
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
So I dropped my car off at my dealership to address the following:
- Rapidly blinking turn signal
- Creaky/noisy seatbelt clip area
- Homelink buttons non-functional
- Drivers window sometimes wont go back up (cold weather)
They said they have to contact Subaru Techline for instructions/guidance on working on the vehicle. Is that a load of bull$h!t, or are they actually needing to consult some other knowledge group?
The Following User Says Thank You to SpectreRT For This Useful Post:
Pat (02-07-2022)
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 09:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 08:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 04:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 10:21 PM
