Old 02-03-2022, 02:49 AM   #1
mamamiaellis
Drives: brz
Carbon build up
Anyone having issues with carbon build up on the bottom of engine block?
I have a ton caked on...
I never really noticed before. This normal?
mamamiaellis is offline   Reply With Quote
Old 02-03-2022, 10:04 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Looks like a small oil leak. Clean it off and recheck. Front crankshaft seal or bottom of timing cover are likely sources.
Old 02-03-2022, 11:36 AM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Also the o-ring at the bottom the dipstick.
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
blsfrs (02-03-2022), SpectreRT (02-03-2022)
Old 02-03-2022, 11:40 AM   #4
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
As the others have stated, this is oil. There was a TSB a while back on this I think. For either the...
- O Ring for the dipstick area or...
- Timing Chain Cover / Valve Cover (I forgot which one).
If you're under warranty, they'll fix it. If its minor, just clean it and enjoy the car.
SpectreRT is offline   Reply With Quote
Old 02-03-2022, 12:24 PM   #5
mamamiaellis
Drives: brz
Thanks yall for the suggestions.
It looks like its all over the bottom of the engine case.
Tbh i have had more than my fair share of track days .
Engine is stock. But i have headers and stuff.
I never got a recall letter. So maybe im on my own.
Ill try out the dipstick gasket first. See if it works.
The Following User Says Thank You to mamamiaellis For This Useful Post:
blsfrs (02-05-2022)
Old 02-03-2022, 03:50 PM   #6
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
There was never a recall; but there was a TSB for customers who notice the situation and want it OEM repaired.
Good luck! Tracking down these issues can be a huge PITA on FA20.
Old 02-03-2022, 04:52 PM   #7
mamamiaellis
Drives: brz
appreciate the help!
more i think about it, i dont think the dipstick can spread carbon out that far.
Ill probably take some time to jack up the car and clean it up.
sigh........ hoping to find the area of issue and just try and externally seal that part.
and hopefully the build up is not inbetween the headers.
blsfrs (02-05-2022)
Percentage of port injection and carbon build up JIM THEO Engine, Exhaust, Transmission 9 01-08-2021 04:59 AM
My Greddy Rocket Bunny V2 Build | Carbon Signal Paul_GT86_dxb Cosmetic Modification (Interior/Exterior/Lighting) 7 10-02-2016 11:41 PM
Carbon build up around intake valves? csaba Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 57 01-13-2015 10:39 AM
eguerin's SSM/Carbon BRZ Build eguerin Member's Car Journals 9 07-08-2014 04:53 AM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 06:53 PM
