Old 12-16-2021, 09:50 PM   #1
subsonicflo
subsonicflo's Avatar
Drives: 2015 BRZ
Sprintex S5-210 Bearing Service
Has anyone inspected seals or changed the bearing for the Sprintex S5-210's?
My unit was previously owned. I find oil leaking onto the rotors and is it the reason why the intake manifold and intercooler were full of gunk.
https://imgur.com/a/BM3Otwh
Does anyone have advice or the torque specifications?
Thanks
subsonicflo is offline   Reply With Quote
Old 01-22-2022, 11:02 PM   #2
sroby
Drives: 2015 Firestorm 08/05/15
Get with Jon Bond Performance. The Sprintex have a design flaw that he will explain. Bottom line they don’t come with Viton High temp seals for the main front bearing rotor pac.
The proximity of the front main nearing and seals are to close to the front gears in the gearbox. It builds up presure in the gear box and over heats the seals pushing the gear oil past the bearings into the rotor pac and intake ports. That’s what you are seeing in yours. Bond can repair it but it’s a total rebuild. Contact Jon he will explain in details. Hope 5his helps
sroby is offline   Reply With Quote
The Following 2 Users Say Thank You to sroby For This Useful Post:
brianbui23 (01-26-2022), kev0 (01-23-2022)
Old 01-28-2022, 09:36 PM   #3
jflogerzi
jflogerzi's Avatar
He may not even be repairing them anymore. But I am sure if anyone can give you the right advice to try on your own its him and maybe some parts.
2013 Series 10 FRS #553
Old 01-28-2022, 09:42 PM   #4
whataboutbob
AutoX-10/10ths every run
You may want to check with Sprintex to see what the cost of just a new blower (no manifold/etc) is Vs. what someone may charge in parts and/or labor to rebuild an old blower.
Build thread:Here
210, bearings, seals, sprintex, torque
Spun Rod Bearing? itsAlex Issues | Warranty | Recalls / TSB 38 03-12-2021 09:03 PM
Spun Rod Bearing Warranty Service Reprobate Issues | Warranty | Recalls / TSB 93 08-17-2018 02:39 PM
Camshaft Bearing FRSloth Engine, Exhaust, Transmission 1 10-15-2016 02:19 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 01:17 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
