Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-20-2022, 07:11 AM   #253
ozafar
Drives: 2015 Scion FRS Release Series 1.0
So there is no hope for a 9.5 rim anymore?
I guess that leaves 17x9 and 18x8.5, and perhaps the rare 18x9 whoever can do that?
ozafar is offline   Reply With Quote
Old 01-20-2022, 08:19 AM   #254
Chris_f
Drives: 2022 GR86
From what I have seen, I will be going with a 18x8.5 +45 with a 235 tire.
Going wider is possible with extra effort… but if you want to lower the car with near stock alignment (minimal neg camber) - this car is just not well suited to super wide fitments
Chris_f is offline   Reply With Quote
Old 01-20-2022, 09:27 AM   #255
Racecomp Engineering
We test fit an 18x9.5 +42 with a 245/35/18 just for fun. Did not fit on OEM suspension, but more than anything it just looks really bad.
We will probably go with an 18x8.5 for our car. Don't really need or want a 9.5 wide wheel anyway.
- Andrew
Old 01-20-2022, 09:41 AM   #256
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
Very unfortunate that's "the" spec for these cars lol. A lot of wheels look less appealing with those specs, little to no concavity.
Robertw is offline   Reply With Quote
Old 01-20-2022, 09:58 AM   #257
patsimca
Drives: 2022 BRZ
I'm biased as I'm targeting wheels for stock suspension but the sweet spot seems to be 8 wide +40 or 8.5 wide +45. Trying to balance flush (as possible), tire size, and good fitment...
As of today I'm thinking 18x8.5 +45 on 235/40/18. Could also go 245/35/18 to keep tire diameter close to OEM spec.
Also considering narrower 18x8 + 45 also on 235/40/18. I like sidewall. But the wheels would be slightly sunken in.
Knowing the paralysis I get when trying to decide, I probably won't buy anything for 4 years.
patsimca is offline   Reply With Quote
Old 01-20-2022, 10:33 AM   #258
I've said this elsewhere, but absolutely nothing wrong with an 8 inch wide wheel for most people. I run a 17x8 on my 1st gen with a 225/45/17 with a nice not quite perfectly flush but very functional offset. It isn't hotboi fitment but also it isn't hotboi fitment.
- Andrew
Old 01-20-2022, 10:51 AM   #259
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yup, that flat face kills so many wheels. It really sucks
Old 01-20-2022, 10:55 AM   #260
Robertw
Robertw's Avatar
- Andrew
It's not about the "hotboi" spec, it's that a lot of wheel designs look better with a little concavity. You don't get that with +45 offsets at 8" widths..
Old 01-20-2022, 11:17 AM   #261
ozafar
I know this thread is for the BRZ, but I'll be picking up my GR86 tomorrow if the test drive goes well....I looked at the rear fender (and I may be wrong) but I think it looks a little different to the Subaru one? If so, maybe the rubbing issue may be easier on the GR86. I'll post pics soon.
Anyone know a nice looking wheel with concavity with 18x8.5 specs?
Old 01-20-2022, 11:26 AM   #262
That's a fair point.
Old 01-20-2022, 11:26 AM   #263
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The rear sheet metal and suspension geometry is identical
Old 01-20-2022, 11:38 AM   #264
ozafar
@DocWalt you are most likely correct. It was a quick look in the cold, I thought it may have been different.
So 18x8.5 is the new widest wheel. (OR 17X9?) What offset do you think will give the best flush without rubbing on the rear fender?
If someone can please answer for stock suspension and coilovers.
Thank you
Old 01-20-2022, 03:34 PM   #265
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
17x9 ET45 fits the rear pretty flushly and no rubbing when lowered. It would probably poke a lot at stock height.
Old 01-20-2022, 05:13 PM   #266
joemysterio
Drives: Mini
Originally Posted by Panda Grahams View Post
Picked the car up from the dealership last night. Immediately swapped the stock wheels/tires to a set of RPF1s 18x8 +35, with winter tires in 225/40r/18. I am thrilled with how it turned out. Zero rubbing, and plenty of clearance to the front strut tower. I plan to lower the car modestly, eventually. Cheers!
I keep coming back to your set up, I like the way it sits and how the tire looks. The wheel (Enkei TS-5) I want only comes in +45 in 17x8 size. Seems like I'll have to play around to get the same exact fitment. Also plan on getting RCE SS-1 Coilovers eventually for a very modest drop, maybe the bare minimum 20mm I read about in a different thread. Man, I can't wait for my BRZ to get built!
joemysterio is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
