Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-08-2022, 09:31 PM   #239
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I hung both of them together by the same eyelet and they appear to be the same. Hard to tell with the slot though.
Old 01-11-2022, 05:29 PM   #240
SockMonkey
Drives: '13 BRZ Limited
Originally Posted by BRZ-G1 View Post
Wanted to add this to the data.
I have 18x8.5 44et with 245/35/18
These are the wheel tire combo with stock suspension. Seem nice and flush. Will likely tuck in a bit more as the car is lowered, gaining a bit more negative camber.
I have installed Ohlin coilovers 2 days ago. Will be adjusting and lowering more from what Ohlins came as. Waiting for them to settle. Will follow up with images when lowered, corner balanced and aligned.
PS: This is my first Subaru. I had high expectations, and mostly it has been surpassed. However, installing the new coilovers, I noticed that the stock rear control arm is literally junk. This thing was warping with torque application, what a shame. I will be looking to replace this piece with an aluminum one. Subaru, not Toyota, also has the front lower control arm made of aluminum vs the same thin steel junk in the GR86. One less thing to worry. If you guys get the GR86, look into swapping with the BRZ aluminum piece. Savagegeese mentions this in his YouTube video as well.
I'm installing the same exact wheels, and I plan to leave the suspension stock except for some Eibach Pro-Kit springs. These should drop the car only about ~0.9", do you think I'll have and trouble?
SockMonkey is offline   Reply With Quote
Old 01-11-2022, 06:03 PM   #241
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Strat_FRS View Post
I have the same SPC arms we will try on our 2022 when putting in the coilovers. Did you happen to measure the distance between the subframe attachment point and the shock and knuckle attachments points between the SPC and 2022 arms?
Based on a discussion on facebook (with pictures) to figure SCCA legality, the hole is about .5" inward on the 2nd gen vs 1st gen RLCA measuring OEM parts
Old 01-11-2022, 06:08 PM   #242
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Can you provide a link to that FB discussion?
So I presume the motion ratio is now even lower than it was before
Old 01-11-2022, 06:21 PM   #243
finch1750
finch1750's Avatar
You commented on it lol.
It's a private group though so I won't post a link.
Old 01-11-2022, 06:25 PM   #244
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Ah, THAT post. Found the new comments there now.
Posting the pictures from there for others here:
gen.1:
(DM me for credits, I don't know your forum handle!)
2022 BRZ:
(Credits: @trippinbillies40)
Old 01-11-2022, 06:28 PM   #245
finch1750
finch1750's Avatar
Thanks. My wifi at work is garbage so trying to load pictures takes ages. It's like Im on dial up lol
Old 01-19-2022, 02:11 PM   #246
jvincent
jvincent's Avatar
For those that weren't aware, TireRack has wheel data for the 2022s now.
And as I expected/hoped it shows that my wheels (PF01 18x8.5 + 48) will fit. Woot!
Old 01-19-2022, 02:21 PM   #247
finch1750
finch1750's Avatar
Interesting. They have 18x9.5 +45 as optional. Given they run conservative that seems promising, but also wonder if thats only at stock height
Edit: Filtering more they also list 18x9.5 +35 as fitting in the rear which we know wont work, at least without extensive fender work, camber, and stretch
Old 01-19-2022, 02:51 PM   #248
jvincent
jvincent's Avatar
I would bet it's at stock height/camber.
Old 01-19-2022, 03:30 PM   #249
finch1750
finch1750's Avatar
So once you add them to cart there are notes for aggressive fits. 18x8.5 +45 and 18x9 +40 did not have notes on checkout. And they are based on stock height and camber. I believe they base this on the tires the package them with which would be 255/35s for the 9.5 widths
18x9.5 +45
18x9.5 +35
Old 01-19-2022, 10:06 PM   #250
86man
Drives: GR86
A HD video (in Japanese) on various wheels & tyres fitment on the BRZ
The takeaway for owners who want to run wide wheels & tyres on stock suspension are
1. 18x9J ET45 (Toyo R1R 255/35) fits front & rear but rear needs slight camber
2. 18x9.5J ET38 (Toyo R888R 255/35) fits the front but won't clear the rear (17:53)
86man is offline   Reply With Quote
Old 01-19-2022, 11:33 PM   #251
ozafar
Drives: 2015 Scion FRS Release Series 1.0
Okay, after reading the entire thread carefully it seems that stock suspension vs coilovers will yield different offset requirements. Just like last gen.
Can anyone help me confirm if 18x9.5 et45 with RCE SS1 Coilovers (comes with front camber plates) will fit without rubbing and without poke?
If 17x9 et42 with coils fits well, I’m wondering if half an inch can fit. The problem is there are so few 18x9 options out there, everything is 18x9.5…
ozafar is offline   Reply With Quote
Old 01-20-2022, 12:48 AM   #252
Kona61
Kona61's Avatar
Drives: ‘22 CWP
I spoke to a few people running that setup and it will rub 100%. You're going to have to cut the rear fender tab and liner similar to a S2000 to fit it.
Also, people are saying that 255/35 is the best size for that fitment. About -3 degrees camber up front and natural -2.5 rear.
Kona61 is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
