#239 |
Drives: 22 BRZ limited
I hung both of them together by the same eyelet and they appear to be the same. Hard to tell with the slot though.
#240 | |
Drives: '13 BRZ Limited
#241 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Based on a discussion on facebook (with pictures) to figure SCCA legality, the hole is about .5" inward on the 2nd gen vs 1st gen RLCA measuring OEM parts
#242 | |
Drives: 2022 GR86
So I presume the motion ratio is now even lower than it was before
#243 | |
It's a private group though so I won't post a link. |
#244 |
Drives: 2022 GR86
Ah, THAT post. Found the new comments there now.
Posting the pictures from there for others here: gen.1: ![]() (DM me for credits, I don't know your forum handle!) 2022 BRZ: ![]() (Credits: @trippinbillies40) |
#245 |
Thanks. My wifi at work is garbage so trying to load pictures takes ages. It's like Im on dial up lol
#246 |
For those that weren't aware, TireRack has wheel data for the 2022s now.
And as I expected/hoped it shows that my wheels (PF01 18x8.5 + 48) will fit. Woot! |
#247 | |
Edit: Filtering more they also list 18x9.5 +35 as fitting in the rear which we know wont work, at least without extensive fender work, camber, and stretch |
#248 |
I would bet it's at stock height/camber.
#249 |
So once you add them to cart there are notes for aggressive fits. 18x8.5 +45 and 18x9 +40 did not have notes on checkout. And they are based on stock height and camber. I believe they base this on the tires the package them with which would be 255/35s for the 9.5 widths
18x9.5 +45 ![]() 18x9.5 +35
#250 |
Drives: GR86
A HD video (in Japanese) on various wheels & tyres fitment on the BRZ
The takeaway for owners who want to run wide wheels & tyres on stock suspension are 1. 18x9J ET45 (Toyo R1R 255/35) fits front & rear but rear needs slight camber 2. 18x9.5J ET38 (Toyo R888R 255/35) fits the front but won't clear the rear (17:53) |
#251 |
Drives: 2015 Scion FRS Release Series 1.0
Okay, after reading the entire thread carefully it seems that stock suspension vs coilovers will yield different offset requirements. Just like last gen.
Can anyone help me confirm if 18x9.5 et45 with RCE SS1 Coilovers (comes with front camber plates) will fit without rubbing and without poke? If 17x9 et42 with coils fits well, I’m wondering if half an inch can fit. The problem is there are so few 18x9 options out there, everything is 18x9.5… |
#252 | |
Drives: ‘22 CWP
Also, people are saying that 255/35 is the best size for that fitment. About -3 degrees camber up front and natural -2.5 rear. Last edited by Kona61; 01-20-2022 at 01:10 AM. |
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
