Northern California NorCal
Old 12-22-2021, 11:47 PM   #71
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Originally Posted by EndlessAzure View Post
Did you have to disclose that the motor isn't original? How did that work?
Nope, i didn’t want to mention anything if i didn’t need to. I was concerned the OEM tune i loaded wouldve pointed me out in their computers but it passed. Car read 2013 and all was good.
Decimus is offline   Reply With Quote
The Following User Says Thank You to Decimus For This Useful Post:
EndlessAzure (12-23-2021)
Old 01-19-2022, 01:27 PM   #72
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Feb 2014 purchased, just got SMOG'd yesterday.
Took off intake because it's bright red, took off mishimoto cloned catch can.
Kept my Tomei 60S exhaust because it's just catback, and subaru oil cooler.
Passed, $49 and visual was just a 2 min glance.
Haven't posted in years.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 01-19-2022, 02:04 PM   #73
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I removed my tune, added back the sound tube, and took it in for a tune. Didn't pass because the car had too few miles since the battery had disconnected. Ran for 100 miles then came in and passed.
Old 01-23-2022, 07:30 AM   #74
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
Originally Posted by EAGLE5 View Post
Somebody had a CARB EcuTek tune and ran into issues, but they got it sorted out with a second test station. I haven't done mine yet.
is the ECU check a visual inspection?.. like the tech just looks at the computer screen to see the name of the ecu tune or is it built into the software check?
Stigmaru is offline   Reply With Quote
Old 01-23-2022, 01:19 PM   #75
EAGLE5
Dismember
EAGLE5's Avatar
I didn't look at the screen. I know the test is entirely digital now. The rollers aren't used at all. People have said the ECU tune is checked, so I went back to stock to be safe. I don't think the car is more or less fun with the stock tune. A little slower, perhaps, but just as fun.
Old 01-23-2022, 01:52 PM   #76
EAGLE5
Dismember
EAGLE5's Avatar
Old 01-24-2022, 04:07 PM   #77
norcalpb
norcalpb's Avatar
I have a friend who has a boxster with a stage 1 tune and they picked it up and failed him for it, so I’d say going back to stock is mandatory.
Old 01-24-2022, 05:05 PM   #78
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I’ve never seen rollers used on obd2 cars, that must’ve stopped well over a decade ago.
Visual and plug into the port as long as I’ve been smogging cars
ineedyourdiddly
Old 01-24-2022, 07:04 PM   #79
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I remember having my 2005 truck (obd2 car) on the rollers in Cal. Then the next time I needed smog, no rollers. I think your timing is about right. About a decade.
Old 01-24-2022, 10:20 PM   #80
EAGLE5
Dismember
EAGLE5's Avatar
I had to smog our Scion xA and xB back when I sold them, and they both went on rollers. 2004 and 2005, I think, and OBD II as well. But that was the last time I had to smog a car until now. I've either had EVs, sold to dealers, or sold out of state.
Old 01-31-2022, 02:58 PM   #81
colobrio
Drives: 2013 BRZ, 6MT, WR Blue
Howdy. I'm in Colorado, which just went to California testing standards this year. And, I'm due in February, so I'm trying to get my head around this. Thanks for all the helpful info in this thread.
I've got an aftermarket exhaust (headers back) and ecutek tune with four maps, none stock. Assuming Colorado is in fact doing it just like California, do I have it straight that to pass I should (1) put the stock headers and exhaust back on, and (2) get one of the maps reflashed back to the stock map?
colobrio is offline   Reply With Quote
Old 01-31-2022, 04:49 PM   #82
strat61caster
Yes.
Yes.
Don’t forget the secondary cat in the oem front pipe. Unclear to me if you’ve removed it or not.
ineedyourdiddly
colobrio (01-31-2022)
Old 01-31-2022, 07:30 PM   #83
jflogerzi
jflogerzi's Avatar
Yes. You can keep anything after the front pipe still on. But others must be stock headers, OP, FP and stock ECU tune.
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
colobrio (01-31-2022), strat61caster (01-31-2022)
Old 04-15-2022, 04:45 PM   #84
FrickingReallySlow
Drives: 2015 FR-S
Anyone know if I smog my car earlier then needed that the 2 year requirement gets automatically extended?
What I mean is I did a smog on 08/2021 which should last me to 08/2023. If I do a smog this year on 08/2022 then I shouldn't need one till 08/2024, Is this true? anyone have experience with this?
FrickingReallySlow is offline   Reply With Quote
California Smog Check Phantobe Southern California 144 06-20-2025 05:16 PM
California owners : smog question Adam_L Engine, Exhaust, Transmission 5 10-14-2016 12:47 PM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 01:52 AM
SMOG Issues SkullWorks Engine, Exhaust, Transmission 8 10-04-2012 02:23 PM
