Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-18-2022, 07:31 PM   #15
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I used an IAG block for my rebuild and they and my very talented FA20 guru engine builder had me use Torco 0-20. Car is amazing.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
NoHaveMSG (01-18-2022)
Old 01-18-2022, 07:38 PM   #16
PenGun
Drives: Red 2019 Subaru BRZ
Originally Posted by AK2112 View Post
Do your own oil changes and document it, including receipts for oil and filters.
This is simple.
I just took a bunch of pictures, the dates are in the EXIF metadata of the JPEGs.
PenGun is offline   Reply With Quote
Old 01-18-2022, 07:43 PM   #17
I have a stack of oil filter box-tops with the odo reading and service date written on them.
Old 01-18-2022, 09:45 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
should just save the box. and put the old oil filters in the box.
just imagine handing the new owner crates of the boxes of old parts with mileages on them... "see? it's all documented!"
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (01-18-2022), Ultramaroon (01-18-2022)
Old 01-18-2022, 09:52 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Tracked first gen with over 90K miles, mostly on 0-20. UOA is clean. Most of the oil change intervals where at manual recommended 7500. Only in the last 18 months had it been pulled from DD duty.
Some of you guys overthink wayyyy too much.
The Following 8 Users Say Thank You to NoHaveMSG For This Useful Post:
C R (01-19-2022), dsc_pat (01-19-2022), Dzmitry (01-19-2022), Midnightsky (01-19-2022), Opie (02-03-2022), soundman98 (01-19-2022), tenderization (01-19-2022), Ultramaroon (01-18-2022)
Old 01-19-2022, 12:46 AM   #20
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
I've been hearing good things about Torco lately.
Midnightsky is offline   Reply With Quote
Old 01-19-2022, 02:22 AM   #21
MisterGoober
Drives: IS300, WRX, STI, Bicycle
Couple Questions:
1. When you did your oil change, was there a crush washer or did you have to scrape off a "sealant" that Subaru used at the factory?
2. Regarding oil, what was the recommendation on the original FA20 for the guys with gen1 experience?
Subaru I believe uses Idemitsu as their OEM for oil. Not sure about Toyota. Curious about what's in the factory fill vs. what Toyota and Subaru will each use moving forward.
I personally wouldn't follow the owners manual and would change the oil far more frequently before worrying too much about about oil brand. Chances are, we drive harder than the typical Ascent or Outback driver.
Any thoughts on Pennzoil? It was my go to on previous Subaru platforms, cheap, plentiful (Amazon/Walmart). I would personally go with Castrol or Pennzoil whichever is better/cheaper and change the oil at 1/2 the suggested interval.
MisterGoober is offline   Reply With Quote
Old 01-19-2022, 09:21 AM   #22
C R
Drives: 22 BRZ
Pennzoil 5W-30 full synthetic is good stuff from what I've read, I ran it on a bunch of my turbo trucks and Explorer ST (twin turbo 3.0). Then again, I think most of the modern synthetic oils are excellent and like NoHaveMSG mentioned, we tend to overthink it. Even the Amazon branded oil seems to be pretty great; have you seen Project Farm's oil testing videos?
The one oil I found recently that has a huge following is Shell's Rotella T6 Diesel Oil, lots of people claiming that's all they use on their trucks/cars and even bikes due to the additive package they use.
C R is offline   Reply With Quote
Old 01-19-2022, 09:30 AM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Couple Questions:
There is no sealant on the drain bolt, just a crush washer.
There is no reason to shorten the intervals unless you are particularly hard on the car. If you really are concerned or want to know, get a used oil analysis done periodically, they are like 20 bucks. Most UOA's on cars that are even tracked regularly come back with the factory service interval being fine. Some guys change it more often, which is fine, just not always that necessary.
I have been running 300V in my car but am thinking about making the switch to Pennzoil. A lot of what I hear about it is that it is great.
Old 01-19-2022, 09:51 AM   #24
TommyW
TommyW's Avatar
For good reason. The SR 5r is as good as it gets and the price reflects that.
Old 01-19-2022, 10:10 AM   #25
This is simple.
This^
To document it you can take it a step further and take a picture of the receipt beside the odometer to show the mileage. This will give you time stamped documentation.
NoHaveMSG (01-19-2022), soundman98 (01-19-2022), Spuds (01-19-2022), TommyW (01-19-2022)
Old 01-19-2022, 03:01 PM   #26
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Couple Questions:
1) https://www.ft86club.com/forums/showthread.php?t=54142
2) change as you need... only variation from the factory interval should be based on your oil itself, which is why I kept doing UOA on it
you can ignore factory recommended intervals all you want but unless you have proof (via a Used Oil Analysis) then it's really just throwing money away. Oil change intervals should be dictated based on need, and usually the need is based on the additives being consumed in the oil.
Oil brand is personal choice. Unless you're trying to get 10/10ths out of the car every day, you don't need anything more than the standard synthetic 0W-20...
Most extended warranty fine print requires a dated receipt within 30 days of the recorded service, if you are doing it yourself. This also means you can't stockpile oil filters or even oil in advance.
Tcoat (01-19-2022)
Old 01-19-2022, 04:42 PM   #27
Yes. For the same reason it would be a bad idea to hold up the same receipt for each change! If you have reached a point in a dispute where you need proof you better make sure you have been honest and up front or it will go badly for you.
Old 01-19-2022, 05:45 PM   #28
dsc_pat
Drives: Too fast
This^
I always film the mileage, the VIN on the door frame, the new filter and the oil jug. Never had a problem with dealers.
dsc_pat is offline   Reply With Quote
The Following User Says Thank You to dsc_pat For This Useful Post:
Tcoat (01-19-2022)
'14 BRZ Glove Box Documentation E_H8 Interior Parts (Incl. Lighting) 0 11-15-2017 01:08 PM
FRS/BRZ needed in SoCal for suspension install/documentation info@BlitzNA.com Southern California 8 07-30-2016 04:04 PM
Carfax 808BRZ Miscellaneous 1 03-26-2015 12:12 AM
Can anyone run a carfax for me? DarrenDriven Off-Topic Lounge [WARNING: NO POLITICS] 0 05-01-2012 02:07 PM
