Old 01-09-2022, 09:25 AM   #1
roboboymega
Cool Oil temp from obd2 port
Hi all, I apologize if I’m posting in the wrong place as this is my first time posting. I have a 2013 Scion FR-S with 155xxxkm on it. Back in the late summer I got a product called autool x60. It’s a gauge that plugs into the obd2 port to display info such as oil temps, coolant temp, etc. Now whenever I’ve done reading about oil temp I see people say that 110°C+ is bad for the engine but my car reads between 107-115°C back and forth even in normal driving and up to 124°C on the track. I was just curious if anyone knows if the obd2 port information is accurate and if 107-115 is really that bad for my engine. I only trust the gauge with a grain of salt as it cost like 40$. For background info this is at all rpm’s, I’m running 0w20, I have uel headers ,a tune with ecutek from delicious and my coolant goes from 87°C to 90°C(At least on the gauge). Again I apologize if there’s some type of rule I didn’t follow as again I am a noob to the forums.
roboboymega is offline   Reply With Quote
Old 01-09-2022, 11:40 AM   #2
Ashikabi
Ashikabi's Avatar
Those temps aren't out of line for oil. I don't see a reason not to trust your tool since it's not gauging anything, just displaying the info from the cars computer.
Sent from my ONEPLUS A5010 using Tapatalk
Old 01-09-2022, 12:18 PM   #3
roboboymega
I guess I’m just overthinking it because I saw someone say that once the oil temps get that high from normal driving that the engine grenades. Thanks for putting my mind to rest!
Old 01-09-2022, 12:52 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
109C is about 228F which is fine which is where I'm at on track. That's high though for street driving but it won't hurt anything.
TommyW is offline   Reply With Quote
Old 01-09-2022, 01:35 PM   #5
Ashikabi
Ashikabi's Avatar
Biggest concern is oil viscosity/lubricity. But those temps really aren't bad.
Old 01-10-2022, 03:29 PM   #6
Danny318
Drives: 2019 BRZ
300f is no problem
Danny318 is offline   Reply With Quote
Old 01-10-2022, 11:17 PM   #7
mikeqin
Drives: GT350
I had the same obd2 gauge. The oil temps always read high. When I double checked with two different obd2 gauges it confirmed my suspicion. The autool gauge was wrong. I ended up buying an aem obd2 gauge to replace it. It was about 30-40 degrees f higher than the true temp
mikeqin is offline   Reply With Quote
The Following User Says Thank You to mikeqin For This Useful Post:
jcw99 (01-14-2022)
Old 01-10-2022, 11:33 PM   #8
Ashikabi
Ashikabi's Avatar
That doesn't make any sense to me at all, since it's not actually gauging anything
The Following User Says Thank You to Ashikabi For This Useful Post:
soundman98 (01-11-2022)
Old 01-11-2022, 08:31 AM   #9
Ohio Enthusiast
Drives: 2018 BRZ
Maybe they're calculating the value wrongly? I know that there was some discussion in the past about the right PID and formula to get the oil temp and there were several options suggested.
I'm using a cheapo Bluetooth dongle connected to Torque Pro on my Android phone and in normal driving oil temps are close to coolant temps (~190 F) and rising to around 220 in more spirited driving.
Old 01-11-2022, 08:37 AM   #10
Ashikabi
Ashikabi's Avatar
Are we sure it's displaying the correct value? Is it showing coolant temp instead of oil? Maybe I'm misunderstanding how these dongles work but as far as I can tell, they just make the already existing information in the computer accessible via Bluetooth. I don't see why they would do any of their own calculations
Old 01-11-2022, 09:03 AM   #11
Ohio Enthusiast
Drives: 2018 BRZ
The dongles just expose the OBD protocol over Bluetooth, that's correct. The apps are what is doing the PID access, value calculation and display.
If the Autool x60 is not reading the right PID or doing the calculation wrong, it would show an incorrect reading.
Old 01-11-2022, 09:14 AM   #12
Ashikabi
Ashikabi's Avatar
You suppose the dongle could be used with the Torque app?
Old 01-11-2022, 10:59 AM   #13
Ohio Enthusiast
Drives: 2018 BRZ
The Autool x60? I doubt it - it comes with its own display and they probably did some proprietary stuff there. But any generic Bluetooth ELM dongle works with Torque.
Note that I couldn't get the oil temp working in the free Torque Lite app. Torque Pro works fine out of the box, though, and was a good investment.
Old 01-14-2022, 12:04 PM   #14
vagthomas
Drives: Toyota GT86
I read also through obd2 and the torque app in android.
Normal driving for me is arnd 100 oC. With spirited driving I reach 120-125 oC. Oil spec 0w-20.
You are ok. No worries. Common temps for the FA20. Just make sure you use good oil
vagthomas is offline   Reply With Quote
0w20, obd2, oil temperature
Engine Oil Temp OBD2 PID for 2017+ Toyota 86 rpons541 Engine, Exhaust, Transmission 1 05-21-2025 04:57 AM
Can the OBD2 port feed 2 devices? Turbo Electronics | Audio | NAV | Infotainment 14 11-23-2018 12:09 AM
Replace faulty OBD2 port? Fizz Software Tuning 3 12-21-2016 02:59 PM
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
is the OBD2 Port on my dashboard universal? Dream20b Engine, Exhaust, Transmission 3 08-08-2015 06:20 PM
