Cleaning direct injectors after E85 use
Is it recommended to simply replace them as opposed to cleaning?
Local dealerships don't seem to have the necessary tools to do the work. If cleaning is alright, any vendor recommendations? New ones are expensive, I have no need for a second set
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#3 | |
Drives: 2013 frs base
#4 |
Drives: Crapcan
There are a number of places that can do it. Dr. Injector, Fuel Injector Clinic.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | SPCorBUST (01-02-2022) |
#5 |
HG performance in San Marco's can do this for you.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | SPCorBUST (01-02-2022) |
#6 |
#7 |
#8 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Does having run E85 for a time make it more advisable to do this? I ran it for about 10,000 miles but can't get it here anymore. I'll have my ESC installation finished in a week and plan to stay with 93 octane after that.
#9 |
Professional wrench
Drives: 2020 BRZ ST RS
what would need to be cleaned after using E85? Its a very clean fuel. what am I missing? I would think that needing cleaning from gasoline is more common as its known to be much dirtier.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
#10 | |
Drives: 2018 Subaru BRZ Limited with PP
#11 | |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
#12 |
btw for anyone reading this, I'd much rather trust CSG to clean and install these than the local subaru dealerships. Local dealership mangled my first set of DI seals and don't do this very often.
#13 | |
Graphite is standard by Bosch for all their high-heat and motorsport applications for GDI. The reinforced are Autofactory seals which are easy to install, stronger, and have a secret sauce that is proprietary to the reinforced seals. |
#14 |
Drives: '14
Is running a few tanks of 93 to 'flush' and 'clean' the injectors not enough anymore? I run 93 for 3 months out of the year and that's when it gets cold here in Chicago. I was under the impression that was enough to keep the injectors clean and healthy. I guess not?
| Clean, Flow Test, Balance Direct Injectors | nexceda | Engine, Exhaust, Transmission | 2 | 12-20-2021 02:23 PM |
| Direct injectors installation issues. | jrhudson | Engine, Exhaust, Transmission | 11 | 11-06-2021 07:34 PM |
| SOLD Direct injectors | bhmax | Engine, Exhaust, Bolt-Ons | 3 | 12-21-2020 03:02 PM |
| Direct Fuel Injectors | Silverspeed | Engine, Exhaust, Bolt-Ons | 0 | 10-20-2016 07:04 PM |
| Additional sealing for direct injectors? | Dmitri | Engine, Exhaust, Transmission | 6 | 05-16-2014 02:40 PM |
