Old 12-29-2021, 01:49 PM   #1
SPCorBUST
SPCorBUST's Avatar
Cleaning direct injectors after E85 use
Is it recommended to simply replace them as opposed to cleaning?
Local dealerships don't seem to have the necessary tools to do the work.
If cleaning is alright, any vendor recommendations? New ones are expensive, I have no need for a second set
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 12-29-2021, 07:48 PM   #2
CSG Mike
CSG Mike's Avatar
https://www.counterspacegarage.com/f...-86-subaru-brz
Old 12-30-2021, 08:42 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Y'all back up and running? I had checked with you earlier in the year and your guy was moving or something.
Old 12-30-2021, 11:37 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There are a number of places that can do it. Dr. Injector, Fuel Injector Clinic.
Old 12-30-2021, 12:47 PM   #5
jflogerzi
jflogerzi's Avatar
HG performance in San Marco's can do this for you.
2013 Series 10 FRS #553
Old 12-30-2021, 03:51 PM   #6
CSG Mike
CSG Mike's Avatar
Yup, back up and in business!
Old 12-30-2021, 04:02 PM   #7
blsfrs
blsfrs's Avatar
I ended up using Injector Pulse here in Virginia. For folks in the east, they are a bit closer and they are a NASA Mid-Atlantic sponsor. Quick turnaround time too.
Old 01-03-2022, 10:31 AM   #8
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Does having run E85 for a time make it more advisable to do this? I ran it for about 10,000 miles but can't get it here anymore. I'll have my ESC installation finished in a week and plan to stay with 93 octane after that.
Qwimby1 is offline   Reply With Quote
Old 01-06-2022, 02:13 PM   #9
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
what would need to be cleaned after using E85? Its a very clean fuel. what am I missing? I would think that needing cleaning from gasoline is more common as its known to be much dirtier.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 01-14-2022, 10:32 AM   #10
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
https://injectorrepair.com/ethanol-problem/
Dzmitry is offline   Reply With Quote
Old 01-14-2022, 12:17 PM   #11
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
What can you tell us about the use of the graphite seals vs reinforced vs OEM? I can't see any physical difference with the reinforced ones from photos. Never met anyone running graphite either? I believe I have one bad seal that's causing a misfire on cylinder one. No matter what Zach does, it's always that cylinder that misfires first and much earlier than others.
B T is offline   Reply With Quote
Old 01-14-2022, 12:19 PM   #12
B T
btw for anyone reading this, I'd much rather trust CSG to clean and install these than the local subaru dealerships. Local dealership mangled my first set of DI seals and don't do this very often.
Old 01-14-2022, 05:01 PM   #13
CSG Mike
CSG Mike's Avatar
OEM is factory.
Graphite is standard by Bosch for all their high-heat and motorsport applications for GDI.
The reinforced are Autofactory seals which are easy to install, stronger, and have a secret sauce that is proprietary to the reinforced seals.
Old 01-14-2022, 05:06 PM   #14
kev0
Drives: '14
Is running a few tanks of 93 to 'flush' and 'clean' the injectors not enough anymore? I run 93 for 3 months out of the year and that's when it gets cold here in Chicago. I was under the impression that was enough to keep the injectors clean and healthy. I guess not?
kev0 is offline   Reply With Quote
Clean, Flow Test, Balance Direct Injectors nexceda Engine, Exhaust, Transmission 2 12-20-2021 02:23 PM
Direct injectors installation issues. jrhudson Engine, Exhaust, Transmission 11 11-06-2021 07:34 PM
SOLD Direct injectors bhmax Engine, Exhaust, Bolt-Ons 3 12-21-2020 03:02 PM
Direct Fuel Injectors Silverspeed Engine, Exhaust, Bolt-Ons 0 10-20-2016 07:04 PM
Additional sealing for direct injectors? Dmitri Engine, Exhaust, Transmission 6 05-16-2014 02:40 PM
