Old 05-13-2014, 02:23 AM   #1
Dmitri
Drives: Turbo BRZ, Celica Supra
Additional sealing for direct injectors?
So it looks like I've suffered an engine failure due to a bad tune resulting in blown injector seals, and knock. Installing new engine and assembling di system with new seals, anyone ever consider adding additional sealing? Possibly high temp silicone of some sort on injector shaft between the Teflon seal and the isolator? Any possible negative side effects besides the injectors being a bit of a pita to remove later on? Im running fi, and thinking additional sealing would be nice.... opinions?
Dmitri is offline   Reply With Quote
Old 05-13-2014, 12:08 PM   #2
Dezoris
Dezoris's Avatar
I think the problem you will run into placing an sealant above the teflon seals is that it needs to be capable of combustion temperatures and extreme heating and cooling cycles.
These systems are obscenely engineered, the DI injectors are very high end in terms of technology. Personally, without knowing why and how they designed the system the way they did. I would not touch it. The DI seals move up the shaft, however is there a perfect seal, or is there just a bit of pressure that gets released up the injector during combustion?
Without knowing that and placing another seal half way up the shaft could be detrimental without plenty of testing.
If I was going to gamble I would place another teflon seal halfway up the shaft as backup. (Assuming the Injector still slid back into tunnel).
But even that is not going to do much if that main seal is gone, except possibly buy you time. Even then it's not like you will know if the main seal is gone unless you get some type of popping.
Old 05-13-2014, 12:22 PM   #3
Basket Case
Drives: 2013 Raven fr-s
Has anyone come up with an upgraded seal yet?
Basket Case is offline   Reply With Quote
Old 05-13-2014, 12:26 PM   #4
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
http://www.autofactory.jp/product/to...=s&pm=t&seq=34
illmatic is offline   Reply With Quote
Old 05-16-2014, 11:43 AM   #5
FAER
Drives: Silver BRZ
Originally Posted by illmatic View Post
wonder if this is truely a "stronger seal" or just the oem with a lil snake oil
FAER is offline   Reply With Quote
Old 05-16-2014, 12:20 PM   #6
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Can anyone on the forum speak for these? Has anyone ordered a set?
On a side note - if the DI seals blow, you hear the popping, can you simply replace and expect no damage to be done? I'm assuming that having a seal blown won't cause immediate damage, but if you keep driving on it, it will?
spitz is offline   Reply With Quote
Old 05-16-2014, 02:40 PM   #7
Dezoris
Dezoris's Avatar
Replace it right away. Should save it but best to do a compression test after.
additional gauges Basket Case Electronics | Audio | NAV | Infotainment 5 04-02-2024 11:14 AM
Sealing And Deadening the Doors WolfSongX Electronics | Audio | NAV | Infotainment 77 04-08-2020 02:35 AM
DIY: Tail Lights - Opening and Sealing So You Can Customize MyRx DIY (Do-It-Yourself) Guides 32 07-22-2017 11:32 PM
Window not sealing NOHOME Issues | Warranty | Recalls / TSB 9 12-12-2012 02:57 PM
Additional Production for FRS!! scioneric CANADA 6 09-21-2012 05:09 PM
