Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-10-2022, 07:11 AM   #15
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Originally Posted by LoneFashion View Post
I’ve never changed my oil myself but I just hit 1k miles in my brz. So, do I always change the oil filter when I change the oil and also, what oil do you recommend?
1. Yes, always replace oil filter.
2. I use 8100 Ecl-Lite, but I am sure that there are lots of products that are in same level or get the job done at the same level.
Stonehorsw is offline   Reply With Quote
Old 01-10-2022, 08:01 PM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yes.
Any full synthetic oil of the appropriate weight will be probably fine. I use Mobil 1 full synthetic on my gen1. I believe API-SP is the latest/best standard, so look for that on the back in a little circular logo.
Old 01-11-2022, 07:18 PM   #17
LoneFashion
Drives: Arriving
Okay cool thanks. Just a few questions if you don’t mind, what things do I need as in special pieces/parts to perform the oil change? I honestly thought all I needed to do was change the oil lol but now I see that I need more things. Obviously I’ve never changed the oil myself but I would like to learn how to.
LoneFashion is offline   Reply With Quote
Old 01-11-2022, 07:26 PM   #18
Stonehorsw
Stonehorsw's Avatar
https://www.ft86club.com/forums/showthread.php?t=9221
Old 01-11-2022, 07:52 PM   #19
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Drain plug washer, a funnel, a oil container to drain into, filter, and maybe a filter wrench/socket.
Kona61 is offline   Reply With Quote
Old 01-11-2022, 08:10 PM   #20
LoneFashion
Drives: Arriving
Thank you so much
Old 01-11-2022, 08:11 PM   #21
LoneFashion
Drives: Arriving
Thank you
Old 01-21-2022, 07:35 PM   #22
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Oil filter options?
For the factory specified oil filter, does anyone have the specifications?
Primarily I'm interested in the bypass pressure rating.
There's room for a much taller oil filter.
Anyone know of one that meets the bypass pressure range?
Scargod is offline   Reply With Quote
Old 01-21-2022, 07:40 PM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Google "Subaru factory oil filter bypass pressure"
lots and lots of info out there from the last 20 years.
Old 06-18-2023, 04:03 AM   #24
Greg Erskine
Drives: Subaru BRZ MY23
I just checked my BRZ 2023 engine after a service. I usually check for oil spills.
This time I noticed the oil filter looks smaller.
The oil filter they invoiced me for is a 15208aa170 but they installed a 15208aa160.
Also, the oil level is 12mm over full level.
Greg Erskine is offline   Reply With Quote
Old 06-20-2023, 04:37 PM   #25
OldBiker
Drives: 2023 Gray BRZ
I wonder if there is a secret dealer directive to overfill... as they did with mine and some others I have heard about. ????
OldBiker is offline   Reply With Quote
Old 06-22-2023, 06:43 PM   #26
Greg Erskine
I went back to the Subaru Dealer where they replaced the oil filter on the spot. Apparently it was an issue with a pick list that is now fixed.
They also spent time discussing and showing me how to check the oil level correctly.
They didn't seem concerned about the oil level being a bit over max.
It seems the car being on flat level surface, the engine being hot or cold and a settling period is enough to vary results that being a couple of millimeters over full is OK.
The guy also spent quite a bit of time discussing tyre pressures as there was some concern about maximizing tyre life on the fronts.
Overall, after the initial error, I can't complain about how helpful the team were.
Old 06-22-2023, 07:28 PM   #27
H380
H380's Avatar
Drives: 2022 BRZ Limited WR Blue MT
The settling period takes a long time on this engine. I wait 30 minutes after I change my oil to check. That is why your oil level is high. The other option is to premeasure the oil.
H380 is offline   Reply With Quote
The Following User Says Thank You to H380 For This Useful Post:
Greg Erskine (06-22-2023)
FS (MD): Grimmspeed Intake, Perrin Inlet/CAI Filter, Green Air Filter s203.22b Engine, Exhaust, Bolt-Ons 1 03-08-2021 12:25 PM
FS: 2 Oil Filters, 1 Cabin Air Filter, 1 Engine Air Filter, 2 Wipers dk127itr Mechanical Maintenance and Tools 7 11-02-2020 11:13 PM
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
