Old 12-31-2021, 03:31 AM   #1
JavieBruh
Drives: 2015 Subaru BRZ Premium
High pitched whine/squeal.
Ive been hearing this high pitch whine/squeal coming from my engine bay for the last few weeks. I at first assumed it was a belt/pulley, so I changed the belt, and checked all the pulleys and they are good. Still can't figure out where or what its coming from. Seems to only happen on cold starts, but once warmed up, seemingly goes away. Anyone have any ideas?
https://imgur.com/a/cLONwG0
JavieBruh is offline   Reply With Quote
Old 12-31-2021, 10:34 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Does it change when you push the clutch pedal in?
The Following User Says Thank You to blsfrs For This Useful Post:
Lantanafrs2 (12-31-2021)
Old 12-31-2021, 11:46 AM   #3
Spairo
Drives: 2013 FR-S 6 spd in Halo
With these car's history, BLFRS asked the best question, push in the clutch and see of the noise changes. Beyond that, does the noise change if you turn the steering wheel while you are sitting still? Does the noise change if you turn on the AC or if you turn on a lot of electrical x especially 4 ways, fans and headlights?
You can also go to your local tool store and get a stethoscope fairly inexpensively so that you can start listening to the bearings in individual components.
Sent from my SM-G950U using Tapatalk
Spairo is offline   Reply With Quote
The Following User Says Thank You to Spairo For This Useful Post:
blsfrs (12-31-2021)
Old 12-31-2021, 11:56 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
and importantly, is it coming from the front or rear of the motor?
also, it looks like your video is in the garage-- take the car outside to diagnose(as much as it sucks in the cold). the garage walls are going to make the exhaust resonate and be noisier, which makes it harder to pinpoint issues like this.
Old 12-31-2021, 04:33 PM   #5
That's TOB for sure.
Old 12-31-2021, 07:36 PM   #6
JavieBruh
Yeah it does actually after doing some more investigation!
Old 12-31-2021, 07:37 PM   #7
JavieBruh
When the clutch is being pushed, it stops. When I have my de-froster on, there is a weird noise being made that seems to come from inside the car.
Old 12-31-2021, 07:38 PM   #8
JavieBruh
It sounds like it is coming from the rear of the motor. The video actually was taken outside lol
Old 12-31-2021, 07:39 PM   #9
JavieBruh
That was my initial thought after it still made the noise after the belt change, and pulley inspection.
Old 12-31-2021, 10:06 PM   #10
soundman98
soundman98's Avatar
sorry, looked like at least 2 walls around the car
Old 12-31-2021, 10:23 PM   #11
Spairo
Sounds like you have finally met the bad clutch throw out bearing.
blsfrs (01-01-2022)
Old 01-09-2022, 03:38 AM   #12
Ronthebiker14
Ronthebiker14's Avatar
Since when does a bad throwout stop making noise when you depress the clutch? A throwout bearing is going bad when its making noise with the clutch pressed in. I can confirm this because my car was doing the opposite and it was the throwout bearing. And every other forum says this.
Ronthebiker14 is offline   Reply With Quote
Old 01-09-2022, 04:20 AM   #13
While your experience is valid, it's not universal. In OP's case, the bearing is dry, partially seized (sticky). It hangs and screeches against the fingers until there's enough pressure to force it to rotate. Common.
Old 01-09-2022, 04:23 AM   #14
Ronthebiker14
That is a possibility but if the bearing was seizing then why would the noise go away when a load is applied to the bearing (pushing in the clutch)? If anything it should make more noise with the clutch pushed in.
brz engine bay
High pitched turbo like whine following rpms Nfsundrgrnd Issues | Warranty | Recalls / TSB 8 02-16-2021 12:02 AM
High pitched squeal only when braking only with a winter wheel PatMegron Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-16-2020 04:57 PM
Squeal/whine when steering wheel is turning motomike Issues | Warranty | Recalls / TSB 4 10-08-2019 07:31 AM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-18-2013 12:00 AM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 02:05 AM
