New ECU regulations in CA?
I have a 2013 FR-S with a tuned ECU (I'll explain). My smog is coming due and I'm concerned that I will fail smog because the ECU is supposedly tuned to remove the well-documented torque. I say supposedly because it came with an ECU flasher and I was told the work had been done. Can I reflash it back to the original? Will the smog tester know or am I ok reflashing it back to the original specs?
#2 | |
Sent from my SM-G975U using Tapatalk |
#3 | |
Dismember
Drives: 2013 Red Scion FR-S
#4 |
Wheels for Brains
I just smogged recently and passed just fine after flashing back from an Ecutek tune to the stock base tune
#5 |
#6 |
Dismember
Then it is pretty easy to use that OpenFlash tablet to restore to stock. After smog, reflash the tune if you want.
I went back to stock recently. I used Tactrix, which is a bit more difficult but not hard.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | strat61caster (12-27-2021) |
#7 |
Drives: 2015 Scion FR-S
I'm so glad i'm leaving CA soon. It's so silly to have to deal with this stuff
| The Following 4 Users Say Thank You to e_lunatic For This Useful Post: |
#8 |
The reflash was insanely easy. Now, after reading my ECU I see there's a PO420 code. I have 3 options...
1) New catalytic converter. Yeah, no. 2) O2 bung. I wonder if the smog technician will open the hood and inspect it. I haven't had a chance to really see where it is or if it would be obvious. Does have a picture of where exactly it's located? 3) Citric acid wash. I've done this before and it works incredibly well. Cat soup anyone? |
#9 | |
Wheels for Brains
You won't pass a real smog visual with an aftermarket header. I recommend either buying a used one or borrowing one and swapping it. The header itself on the FA20 engine has a catalytic converter, along with the front pipe. The only exhaust emissions sensor is located on the header; it's near the header-to-overpipe connection. In the area pictured below, you'll find a pair of twin connectors (one black and one gray); these are for the Heated O2 and AFR sensors on the header, respectively. P0420 deals with the black O2 sensor; follow the black sensor connector and wire down on the left side of the engine |
#11 | |
#12 |
Wheels for Brains
| The Following User Says Thank You to EndlessAzure For This Useful Post: | soundman98 (12-31-2021) |
#13 | |
2013 Series 10 FRS #553
#14 |
| EU Alert: Toyota GR86 on sale for just two years due to new regulations | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 8 | 12-04-2021 12:31 PM |
| Japanese Super GT’s New Regulations Previewed on Toyota GT 86 | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 09-16-2014 01:37 PM |
| New F1 regulations: significant redesign of vehicles | 1Cor10:23 | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 12-07-2013 08:51 AM |
| 2012 ARC Regulations | coyote | AUSTRALIA | 4 | 12-05-2011 01:48 AM |
