go_a_way1
Old 12-22-2021, 04:05 PM   #4425
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Based on my experience, I believe they would all clear the front struts.
Only advice I’d give is 235/40 is too tall IMO. 245/35 is much closer to stock rolling diameter.
ACT86 is offline   Reply With Quote
Old 12-22-2021, 06:52 PM   #4426
NJ-JDM
Drives: 2013 BRZ Limited
Thanks. I can’t tell you the amount of time I have spent on tire height calculators over the years for various project cars. Maybe I will try and sell my left over wheels and tires as a package first. BMW fitment. Before ultimately deciding to use that taller size on the 86.
Any other suggestions for wheels I am overlooking? Or sources for wheels? I spent some time on fitment industries site as well.
2013 BRZ Limited
NJ-JDM is offline   Reply With Quote
Old 12-22-2021, 07:05 PM   #4427
ACT86
ACT86's Avatar
No worries mate.
I recall there were some decent looking enkei’s around in the 18x8.5 fitment, but I haven’t looked in a little while.
Old 12-22-2021, 07:55 PM   #4428
NJ-JDM
No worries mate.
After finding the meaty tire thread another thought would be to just use the 235/40 upfront and look at going staggered. Then picking up the correct diameter tire for the rear. Wheel see. LOL.
Two decades ago I ruined the ride of my Miata by adding 15” Borbet wheels. They were so much heavier than stock. We barely had the internet back then.
2013 BRZ Limited
Old 12-25-2021, 09:08 AM   #4429
SCFD
Will this fit? (No rubbing and tire tread is not exposed when viewed from top of fender.)
17x9 +40
255/40R17
-2.5* camber (eccentric bottom + OE crash bolt top)
Stock suspension
SCFD is offline   Reply With Quote
Old 12-25-2021, 11:53 AM   #4430
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
17x9 +40
255/40R17
Stock suspension
Probably rub on the spring perch and close to the fender depending on how wide the 255 runs
Old 12-29-2021, 05:02 PM   #4431
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
Hi all,
is there anyone how has expierience with a REAR (!!) 10.5 or 11 inch wide rim while maintaining REASONABLE camber (arround - 1.5) and with stock body?
I calculated a offset of +48 for 10.5J and +54 for 11J to have the same fitment on side of the fender based on my current setup which is 9.5J +35.
I plan to run a 285/30 on a 11 inch wide rim (ideal) to have the same stretch as on fromt axle, where I want to keep the 245/35 Im running currently.
The question is, if this can fit at the inside. Im sure the braket for the E brake cable will need modification, but I also dont see a big issue in this. But Im unsure about the top mount/strut tower. Can somebody say out of expierience if 10.5 or 11 inch width is possible with the named offset and camber?
Thanks in advance!
To be very clear: Im just asking for the rear axle. Its clear for me that this will not fit on the front axle.
TRS is offline   Reply With Quote
Old 01-19-2022, 02:44 PM   #4432
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
Originally Posted by TRS View Post
I plan to run a 285/30 on a 11 inch wide rim (ideal) to have the same stretch as on front axle, where I want to keep the 245/35 I'm running currently.
You can run 285/30's on 18x10 square with +40 with the right suspension components, you need front LCA, rear LCA, and rear UCA to narrow the track slightly. Don't know about anything wider then that on stock body but would imagine the wider rim won't clear the strut since it barely does in the setup above I mentioned.
Axis2011KR is offline   Reply With Quote
The Following User Says Thank You to Axis2011KR For This Useful Post:
TRS (01-21-2022)
Old 01-20-2022, 02:13 AM   #4433
tor_oce
Hey all
New to the BRZ/86 community, have had other Nissans and Subarus in the past.
With a stock suspension setup, would a set of 18x9.5 +38 with 235/35/18 fit well?
I understand they'd have poke (roughly around ~1cm if my math is right)
Any help would be appreciated
tor_oce is offline   Reply With Quote
Old 01-21-2022, 06:26 AM   #4434
TRS
TRS's Avatar
Originally Posted by tor_oce View Post
Hey all
Im running 9.5J18 - 35 wrapped in 245/35 square, slightly lowered and camber correction front and rear. This fits pretty well and dont have any rubbing issues. I have a 9.5J18 - 38 for drifting as well. If I use this rim in the front it slightly rubbs the front stabilizer when wheels are fully deflected.
If stock suspension or not, it will NOT fit on the front axle without camber correction. Expect - 2° for a resonable fitment.
Old 01-21-2022, 06:31 AM   #4435
TRS
TRS's Avatar
Concerning not clearing the strut: Are you refering to front or to rear axle with that?
Old 01-28-2022, 01:06 PM   #4436
Axis2011KR
Concerning not clearing the strut: Are you referring to front or to rear axle with that?
I believe it's equally tight on both inward. The same guy that was running that setup is on a 305 now with a slight poke and same wheel offset outback FWIW.
Velox makes a steering rack limiter kit too if you're worried about it scrubbing at full lock. I've got one for my car but haven't installed it yet.
Old 01-31-2022, 11:48 AM   #4437
yEEt42069
Drives: 2018 Subaru BRZ
Will this clear the PP Brembo brakes?
ENKEI GTC02 17x8.5 +40
or
ENKEI GTC02 18x9.0 +42
yEEt42069 is offline   Reply With Quote
Old 02-03-2022, 05:52 PM   #4438
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
or
ENKEI GTC02 18x9.0 +42 5x100 will fit and clear the PP brakes.
The Following User Says Thank You to gen3v8 For This Useful Post:
yEEt42069 (02-03-2022)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
