Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-18-2021, 05:49 PM   #127
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Originally Posted by Yoshoobaroo View Post
Is anyone going to try reasonable daily sizes/offsets? I have absolutely no interest in stuffing a 9.5” wheel in there, or doing any cutting.
Let’s see some cars with ~8.5 40ET, that’s a good bit more aggressive than stock and we frankly need better wheel selections in the 8-8.5” widths. I’m tired of being forced to choose between 7.5” ET45 and 9.5” ET30 with virtually no middle ground. The only wheel company I can think of that has a decent selection in that middleground is Enkei.
I don't have my car, yet, but I'm planning to run some 18x8+35 RPF1s. Hopefully it will turn out well.
Panda Grahams is offline   Reply With Quote
The Following 2 Users Say Thank You to Panda Grahams For This Useful Post:
DustinS (12-18-2021), Yoshoobaroo (12-18-2021)
Old 12-18-2021, 08:06 PM   #128
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
I have 17x9 ET 35 Wedssport TC105N with Yokohama AD08R 245/40R17 I will be trying. The car is due sometime in January.
slipstream8 is offline   Reply With Quote
The Following 2 Users Say Thank You to slipstream8 For This Useful Post:
wheelspeed (12-19-2021), Yoshoobaroo (12-18-2021)
Old 12-18-2021, 08:42 PM   #129
sds
Drives: '22 BRZ Limited 6MT
I'm planning on Advan RG-4, 18x8.5 +44, with 245/35/18s. I feel like that's the perfect combination.
It's a shame it won't look as "concave" as the 18x9.5 options, but I also don't think it makes sense to put 9.5s on a street car with ~210whp. If you track, go for it.
sds is offline   Reply With Quote
The Following User Says Thank You to sds For This Useful Post:
Old 12-19-2021, 12:24 AM   #130
eyeballs
Drives: '22 BRZ
I've got a set of 17x8 +40 konig ultraforms and 225/45 yoko v601 sitting in the basement to go on in spring. Not mounted up yet, so I'm unable to test fit.
eyeballs is offline   Reply With Quote
Old 12-19-2021, 01:41 AM   #131
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The reason it's important for the community to figure out how to fit the widest wheels/tires possible and determine the "optimal" offset for that is that once that's done you can do a bit of math, and figure out the optimal offset for clearance/fitment for any narrower wheel/tire.
From what I understand so far, fitting anything wider than 9", or even the 9"s will be a challenge. That's a major letdown, given that the 1st easily fit 17x9 wheels in the back, and it was a very common size among people who went to tracks, or just wanted a good fitment.
Another factor here is that a lot of people already had wheels for the 1st gen and you can't just use spacers to fix the geometry; you have to buy new wheels, at least in the rear.
There were enough of 17x8 options (at least for me; notably from König), but 17x8.5" were indeed uncommon.
Trust me, it was even worse when it came to wheels that clear Brembo's. That's another reason why I eventually decided to get 17x9's.
I think et40 will be slightly too little for 17x8.5" in the rear, and my bet is the et43–et47 range instead.
And then in the front you'll probably need et30-ish to match the fitment
IMO there's no way it's going to fit in the rear, sorry
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
RippedManiac (12-29-2021), Yoshoobaroo (12-19-2021)
Old 12-19-2021, 09:09 AM   #132
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea I get it, I just feel like there’s a n initial push to see what the biggest wheels that fit the car are, and once that’s done most suppliers/distributors just call that good enough and don’t look into more DD setups for normal cars. This happens for most car platforms I’ve been involved in. Finding stock-like widths with better offsets always turns into an experiment.
The track increase combined with the rear fender aero makes the rear wheel fitment significantly more aggressive than the front. I think this gen we’ll see more people running spacers in the front only, or more aggressive spacers up front.
Old 12-19-2021, 11:35 AM   #133
DarkSunrise
DarkSunrise's Avatar
I'm going to try 17x8 +42 Wedssport TC105N and 17x9 +42 Apex ARC-8. Both with 235/40/17 tires. Only problem is my BRZ isn't due to arrive for a few months with all the delays
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 12-20-2021, 10:14 AM   #134
OkieSnuffBox
Drives: '23 BRZ Limited
Why? The previous page literally says that size they need to cut the rear and front fenders?
I believe Forgestar makes custom wheels for at pretty decent prices. They are "flow formed" so not a fully forged wheel. But they also aren't $3600 a set like BC Racing.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
bholliday (12-21-2021), Yoshoobaroo (12-20-2021)
Old 12-20-2021, 08:50 PM   #135
slipstream8
Sorry, I guess that didn't click in my head.
Do we know if any combination of camber and/or switching to 235s might squeeze in? If not, I'm sure there is a first gen owner out there who would love to have a nice set of lightweight wheels.
Old 12-21-2021, 06:59 AM   #136
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Seems like a lot of talk about what fits, and what doesn't.
I am on 17x9 45 offset with 245/40/17 A052 that run wide. My car is lowered pretty good and I have no rubbing on the rear. I chose to run 5mm spacer up front to match.
Right now front camber is -3.5 rear is 2.4-2.8 I also tried -4.8 front.
Ride height is 13" hub to fender. Easiest way to measure this is to first measure the wheel and divide by 2. Then hook the tap measure at the bottom of the wheel and measure to the fender....then take that number and subtract the number you ended up with from half the wheel.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 10 Users Say Thank You to Simmons For This Useful Post:
bholliday (12-21-2021), DocWalt (12-21-2021), dsc_pat (12-21-2021), DylanJZA (05-02-2022), Fletch (12-21-2021), OkieSnuffBox (12-21-2021), Pete (12-21-2021), Racecomp Engineering (12-21-2021), Spankopotomous (12-27-2021), timurrrr (12-21-2021)
Old 12-21-2021, 10:23 AM   #137
OkieSnuffBox
Looks great!
It would also really help if people shared some additional information:
- Camber front and rear
- Height from pinch weld/jacking point vs stock so we can compare exactly how much a car is lowered, front and rear
Old 12-21-2021, 10:56 AM   #138
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
What you actually want are hub to fender measurements. Pinch weld to ground is affected by tire OD.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
bholliday (12-21-2021), Simmons (12-21-2021)
Old 12-21-2021, 12:27 PM   #139
Simmons
Simmons's Avatar
Looks great!
Added to my post
The Following User Says Thank You to Simmons For This Useful Post:
Old 12-21-2021, 01:55 PM   #140
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Right now [...] rear [camber] is 2.4-2.8
Can you drive one of the rear wheels on something like a curb or a ramp, and take some photos from behind?
The Following User Says Thank You to timurrrr For This Useful Post:
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
