Old 12-20-2021, 03:44 PM   #1
Zaraia
Drives: 2015 Scion Frs
Coolant leaking into cab…
Hello everyone, i went to go get in my car the other day when i found a red puddle on my floor mats, thankfully i bought some hard plastic weather tech mats, but the leak was on the driver side of my car. I proceeded to remove the entire dash because i couldnt see where the leak was coming from and i figured if i was gonna fix it at all id have to remove it anyways. I have no idea what this part is, i lack knowledge on this aspect, I’ve never even heard of this issue, that being said i would greatly appreciate any input you guys could add and or give me on what to do next, what part im looking at replacing or fixing or anything.
Thank you.
P.s. where im pointing to in the pictures provided is where the leak is coming from.
Zaraia is offline   Reply With Quote
Old 12-20-2021, 03:51 PM   #2
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
I would think it has to be the heater core or the connection to the heater core. may have to pull line from firewall side. hard to tell exact from pics. Look for a parts breakdown and follow the coolant lines to and from the heater core.
Best of Luck.
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
Zaraia (12-20-2021)
Old 12-20-2021, 03:59 PM   #3
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
100% ^^^ Especially if your engine coolant is that color
The Following User Says Thank You to gen3v8 For This Useful Post:
Zaraia (12-20-2021)
Old 12-20-2021, 07:54 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
engine coolant should be subaru super blue. a very dark blue. unless someone changed it.
Old 12-20-2021, 08:11 PM   #5
Even if red coolant that is a funky color!
soundman98 (12-20-2021)
Old 12-20-2021, 08:15 PM   #6
soundman98
soundman98's Avatar
almost looks like red locktite...
Old 12-20-2021, 08:16 PM   #7
Zaraia
From what I remember my coolant has always been the Toyota red/pink coolant, it's news to me that it's supposed to be the Subaru blue one, now I'm thinking "did this red coolant mess up my heater core since it's the wrong one?"
Old 12-20-2021, 08:35 PM   #8
If all one or the other you shouldn't have much issue. If two different were mixed it can indeed cause corrosion issues. That is a weird colour and could very well be the result of mixing two incompatible coolants.
Old 12-20-2021, 08:47 PM   #9
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Well since the dash is already mostly removed, go ahead and replace the heater core.
Old 12-21-2021, 09:11 AM   #10
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
FLEX SEAL!!! j/k i also never heard of this issue before
Old 12-21-2021, 12:17 PM   #11
Zaraia
do you think an a/c delete kit would stop the leaking? its coming from the hoses that lead back to the engine, not the hoses that come from the a/c compressor. i cant seem to figure out how to remove the bar in front of the heater core on the interior of the car, I never use my a/c and I'm willing to just buy an a/c delete kit to just get the leaking to stop.
Old 12-21-2021, 12:22 PM   #12
All depends on exactly where it is coming from. To be honest I am truly baffled by that weird colour.
Here are the service manuals that will show you how to get it apart.
https://gt86stuff.onrender.com/t3Portal/
Zaraia (12-22-2021)
Old 12-21-2021, 12:24 PM   #13
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Not the A/C. You need to just join the two heater hoses. Trace them to the engine, disconnect and use 1 piece of hose connecting the two outlets.
Zaraia (12-22-2021)
Old 12-21-2021, 02:19 PM   #14
Project_1796
Drives: Scion FRS 10 series
Toyota does have a FRS/GT86 specifc super blue coolant for our cars, someone messed up putting red and some corrosion happened. I just replaced my heater core, to remove the crash bar you need to remove 8 bolts theres 2 T40 torx bolts on each driver side and passenger side of the bar, then 4 14mm bolts on the transmission tunnel that needs to be removed, also
I had to disconnect the steering shaft from the single 12mm bolt that connects to steering rack, I removed the 14mm bolt that attaches bar to chassis same area as the steering shaft bolt. That should give you enough room to pull out the whole unit, also the a/c system needs to be recovered too before removal, good luck
Project_1796 is offline   Reply With Quote
The Following 2 Users Say Thank You to Project_1796 For This Useful Post:
soundman98 (12-21-2021), Zaraia (12-22-2021)
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
