Drives: 2022 BRZ Premium
Has anyone tried the Powerbass OE direct replacement speakers?
https://www.crutchfield.com/S-iVLVPR...c&awug=9025150
Was searching for some stereo upgrade components and ran across these. Has anyone tried them and can confirm they fit? Would be really nice to have a direct fit replacement for the stock stereo. These aren't listed as fitting the 86/BRZ, but they look like they would and there is one review saying they worked in a '13 FRS. Let me know! Thanks. |
#2 |
ProCrastinationConsultant
the woofers look like they'd mount up, and the tweeter wiring connection looks correct.
i can't say if the tweeter mounting is correct though. the built-in high pass crossover on the woofers means that they're incompatible with the bass-only setup of the factory amp-- the amp would need to be bypassed in order for them to work properly.
#3 | |
| The Following User Says Thank You to soilent For This Useful Post: | soundman98 (12-09-2021) |
#4 |
The tweeters look really easy to alter
#5 |
#6 | |
https://smile.amazon.com/dp/B07RMZ4C...lig_dp_it&th=1 but you need to roll your own crossover, or buy a tweeter with a built-in crossover. personally, i'm currently running a full-active setup off an alpine v9 with peerless xt25sc90 ring radiators serving tweeter duty. previously, i've run dayton 3.5" point source, as well as dayton audio AMT, and hivi q1r at different times of restlessness.
#7 | |
I do have some BC25s lying around though. What do you think of those? The XT is probably a better off axis performer though huh? Last edited by soilent; 12-17-2021 at 12:48 AM. |
#8 |
not really. i just tinker
i tend to find most car audio tweeters and hard domes too harsh, so i play more with custom audio stuff more in search of a more natural tone. i tend to find myself gravitating towards dayton and peerless gear, not for any particular reason, other than the spec sheets seem to more lend themselves towards what i'm looking for in either tone, or just a different approach. i recently bought a set of aiyima tweeters that copy the peerless design, but haven't had a chance to mount them up to try yet. https://www.alibaba.com/product-deta...9ddd6b7f6TURTa
#9 | |
Drives: 2023 WRB BRZ Limited
| The Following User Says Thank You to EmperorJJ1 For This Useful Post: | soundman98 (04-08-2022) |
| Need some help with replacement speakers | reynierpm | Electronics | Audio | NAV | Infotainment | 6 | 08-14-2017 11:46 AM |
| Door speakers upgrade / replacement | mike_ekim1024 | DIY (Do-It-Yourself) Guides | 13 | 02-17-2015 08:29 PM |
| Best inexpensive door replacement speakers? | Prog | Electronics | Audio | NAV | Infotainment | 3 | 12-05-2013 12:32 PM |
| Is there a Direct Fit Map Sensor replacement | sw20kosh | Forced Induction | 10 | 07-04-2013 09:21 AM |
| Best drop-in replacement speakers | RYU | Electronics | Audio | NAV | Infotainment | 4 | 10-10-2012 03:15 AM |
