Old 08-01-2017, 06:17 PM   #1
reynierpm
Drives: Toyota 86 2017 Black
Need some help with replacement speakers
I have read this:
Tweeter: 1"
Midrange: 3.5" (Depth: 2")
Woofer - 6.5" (Depth: 2" without spacers)
Rear - 3.5" (Depth: omgwtfbbq a.k.a. enough)
And I am trying to figure it out whether the following speakers component will fit or not in my Toyota 86 2017.
  • JL AUDIO C5-650: 6.5", 3/4" Silk soft dome tweeters, Top-mount depth: 2-1/2"
  • JL AUDIO C3-650: 6.5", 1" Silk soft dome tweeters, Top-mount depth: 2-9/16"
My concern regarding those two goes to the depth since none match the 2" as per OEM speakers. Will any of those work in my car?
Also I am planning to use the PIONEER TS-G1045R as the mid-range both in the dashboard and rear, same answer they will feet?
Thank you in advance
reynierpm is offline   Reply With Quote
Old 08-01-2017, 09:34 PM   #2
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Check out crutchfield.com
They have all the answers
winstonscifi is offline   Reply With Quote
Old 08-01-2017, 09:43 PM   #3
reynierpm
I have tried with them and they said only C3 600 are compatible which I'm not sure at all, that's why I'm asking for some support
Sent from my SM-G955U1 using Tapatalk
Old 08-02-2017, 11:17 AM   #4
Chimera
Drives: FRS
check out this guys website
http://carstereoadapters.com/
He makes adapter rings for the doors, which help with the mounting depth. I have spr-60c which has a mount depth of 2-3/8, and have some room to spare.
Old 08-14-2017, 10:01 AM   #5
reynierpm
Hi there, so following @Chimera suggestion I did bought those adapters and everything fits properly at the end I finished installing the following:
  • JL C5 650
  • Pioneer TS-G1045R Dual Cone
  • Kicker 43DSC3504 3-1/2-Inch
  • Pioneer GM-D9605 Gm Digital Series Class D Amp
Now I am on the pursuit of a good sub-woofer that sit on the trunk at the side. I have researching a lot and so far I got this two only:
For the first one I am only interested on the sub-woofer but I can't find any selling it separately, only the whole system.
The second one is an expensive one.
Any other suggestion?
Old 08-14-2017, 10:32 AM   #6
Chimera
Drives: FRS
  • JL C5 650
photos?
Integrity Concepts might be more up your alley, they do custom boxes for both 8 and 10in speakers that are side of the trunk style. I thought about them for a long time before ending up going with the stealth box.
one nice thing about Integrity Concepts is you can get matching right and left pods if you want 2 speakers, and they offer more customization options for color and stuff than other people.
MTX has a box iifc, and there's also wickedcas magic boxes, I have no experience with either of those boxes other than being aware of their existence.
Old 08-14-2017, 10:46 AM   #7
reynierpm
Well I didn't make the install so I took no photos at all and the ones I can provide right now is just the amp sit on the back of the trunk other than that all the speakers fits properly and are using the grids now, apologies for not to take photos.
Has anyone tried to replace the rear speakers with a sub and/or larger speakers? soilent Electronics | Audio | NAV | Infotainment 9 12-28-2017 03:48 PM
Door speakers upgrade / replacement mike_ekim1024 DIY (Do-It-Yourself) Guides 13 02-17-2015 07:29 PM
Best inexpensive door replacement speakers? Prog Electronics | Audio | NAV | Infotainment 3 12-05-2013 11:32 AM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
Best drop-in replacement speakers RYU Electronics | Audio | NAV | Infotainment 4 10-10-2012 02:15 AM
