Old 07-03-2013, 09:11 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Is there a Direct Fit Map Sensor replacement
Just wondering if anyone had played around with one from say a wrx or sti?
Old 07-03-2013, 09:17 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
http://www.ft86club.com/forums/showthread.php?t=39823
Yes there is.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
sw20kosh (07-04-2013)
Old 07-03-2013, 09:45 PM   #3
robispec
Drives: Black frs project
omnis have had a checker past any OEM parts work?
robispec is offline   Reply With Quote
Old 07-03-2013, 10:00 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
Could use a Honda K-series OEM. It's the same part. STI's use a different piece all together.
Old 07-03-2013, 10:10 PM   #5
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
no issues what so ever with my Omni 4bar...
Silverdub is offline   Reply With Quote
Old 07-04-2013, 12:21 AM   #6
robispec
the K series does Pressure?
Old 07-04-2013, 12:27 AM   #7
FA20Club.com
Drives: 2013 White Out FR-S
yes 11 psi. already tested it and got the scaling for the ecutek software
FA20Club.com is offline   Reply With Quote
Old 07-04-2013, 12:46 AM   #8
robispec
sweet! thanks!
Old 07-04-2013, 01:48 AM   #9
sw20kosh
Do I assume that the tune will be all off if I replace my stock map sensor with an omni 4 bar or k series sensor?
Old 07-04-2013, 06:07 AM   #10
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Yep, if you change your map for one that can read more pressure, you need the tune that goes with it
The Following 2 Users Say Thank You to Silverdub For This Useful Post:
Sportsguy83 (07-04-2013), sw20kosh (07-04-2013)
Old 07-04-2013, 08:21 AM   #11
mad_sb
Drives: 2013 Asphalt FR-S
There are several manifold pressure based fueling / load compensation tables in the rom. If you change the sensor without re scaling the sensor in the rom, the reading will be all off which will give a false input for the comp tables which will throw off the fueling and the load reference the ecu uses
At a minimum, you need a rom with correct sensor scaling for the sensor you will use.
The Following User Says Thank You to mad_sb For This Useful Post:
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
*PRE-ORDER OFFER* Get YOUR FR-S/BRZ Direct Replacement TODAY! | TWM Performance TWMPerformance Transmission and Driveline 7 03-18-2013 04:26 PM
Toyota badges direct replacement for Scion ones? seven Cosmetic Modification (Interior/Exterior/Lighting) 2 10-12-2012 10:11 PM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
