Old 12-14-2021, 10:01 PM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
What should I do about a tire has been patched by a tire chain shop, but is still lea
I sprayed soapy water over the patch, and not a single visible bubble formed, but there's a very slow leak on the tire as my TPMS has constantly went off and putting air in it fixes the problem. Are tire patches supposed to stop air completely or is it a fallible repair method?
ghostzfh is offline   Reply With Quote
The Following User Says Thank You to ghostzfh For This Useful Post:
humfrz (12-17-2021)
Old 12-14-2021, 10:22 PM   #2
Grady
Grady's Avatar
If the patch is not leaking then keep spraying soapy water until you find the leak. Then ether fix yourself out have it fixed by the “Tire Chain”. Check the bead area and the service valve.
The Following User Says Thank You to Grady For This Useful Post:
ghostzfh (12-15-2021)
Old 12-15-2021, 02:26 AM   #3
radroach
Drives: car
If the leak is slow enough, just keep adding air to it. I added air to a leaky tire every day for a couple years.
Old 12-15-2021, 07:58 AM   #4
Check the bead. Often a tire that has gone flat will get a tiny bit of debris between tire and the rim (the proper use of the word rim!) and have a slow leak.
ghostzfh (12-15-2021), RToyo86 (12-15-2021)
Old 12-15-2021, 09:26 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Check the wheel for cracks as well.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 12-16-2021, 09:02 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
A professionally done inside patch is very strong and unlikely to leak.
Like others have said, it's probably coming from somewhere else. Check to see if you don't have another puncture somewhere, if it's leaking from the bead (check both the inside and outside bead), if it's leaking from the TPMS stem or schrader valve, or if the wheel is cracked. Soapy water is your friend.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
ghostzfh (12-17-2021)
Old 12-17-2021, 02:21 AM   #7
Properly patched tires don't usually leak where patched.
A sloooooow leak can be pain to find. Bubba suggests getting or borrowing a kiddie pool, fill it with water, submerge the tire and look for the bubbles.
If you don't see any bubbles, your TPMS system is jest ah messen wich ya.
Old 12-17-2021, 02:39 PM   #8
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
just fill air every other week lol
Old 12-17-2021, 02:43 PM   #9
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I'm voting for having them remount the tire, as it is likely leaking at the bead. Should be no charge as they just patched it.
Old 12-17-2021, 10:20 PM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
A tire patch isn't a force field around a tire that prevents it from ever losing air again.
Maybe you've got something else poking the tire
Maybe it's losing air at the bead
Maybe it's a 2016 in the mid-atlantic region and corrosion has made it's way around the valve stem
Spray soapy water everywhere. all the tread, beads, valve, inside lip of the wheel. Everywhere.
Best tire shop around LA Jetyn Southern California 5 10-02-2017 07:07 PM
Can this tire be repaired/patched? tracerit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-11-2017 09:56 AM
Tire Blown - Recommended Tire Repair Shop? chermo12 CANADA 3 07-27-2015 12:20 PM
GTA Tire Shop aghuman CANADA 18 06-04-2015 07:35 PM
Tire Shop? Billylammerkins Northwest 5 11-27-2013 06:48 PM
