go_a_way1, MisterSheep
Old 12-10-2021, 01:51 PM   #23465
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Short shifter is about throw, not height. Throw is a little over half stock even at that height.
CAE is porn. I am an IRP peasant.
Ooo, I hadn't run across the IRP before. How do you like it?
Cephas is offline   Reply With Quote
Old 12-10-2021, 02:02 PM   #23466
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s pretty good. It rattles though so it is annoying. On mine I find I have to be more deliberate with my shift into 5th gear when driving hard.
Cephas (12-10-2021)
Old 12-10-2021, 02:33 PM   #23467
Cephas
Cephas's Avatar
Do you have the v3 with the anti-rattle bits? Been reading mixed feedback on that.
Old 12-10-2021, 02:36 PM   #23468
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes it is the updated V3. I believe a lot of it comes from the way it interfaces with the rod from the transmission. The stock shifter has rubber and nylon bits where the shaft goes into the shifter. The IRP has a metal bushing.
Cephas (12-13-2021)
Old 12-12-2021, 07:38 AM   #23469
grumpysnapper
grumpysnapper's Avatar
Originally Posted by Cedric View Post
CAE short shifter installed.
Looks fantastic!
Any rattles at high revs with this unit?
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
Cedric (12-13-2021)
Old 12-12-2021, 10:15 PM   #23470
Decep
Drives: 2013 FR-S Series 10
Installed the whiteline transmission insert (i've had the Perrin rear shifter mount and STI engine mounts installed for a while). For anyone who's installed the Perrin rear shifter mounts, highly recommend you finish the job and add the whiteline transmission insert. It got rid of so much of the bucking/back and forth when coasting or trying to lightly add throttle in stop and go situations. If you're not going to do both i wouldn't do either one.
Noise- a lot more noise in 2nd gear (whining) but i find it fun.
Vibration- a lot more when the engine is cold. When warmed up i can't say its a huge deal.
But these two mods make it so much easier to downshift it's crazy, shifter just snicks into gear whereas before i'd either have to wait for it to slide into gear or just double clutch. Especially downshifting to 2nd gear.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-13-2021, 09:23 PM   #23471
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Car wash and gas. It's cleanish.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
beltax90 (12-14-2021), DarkPira7e (12-28-2021)
Old 12-13-2021, 10:46 PM   #23472
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by grumpysnapper View Post
Looks fantastic!
No rattles
Cedric is offline   Reply With Quote
The Following User Says Thank You to Cedric For This Useful Post:
grumpysnapper (12-14-2021)
Old 12-19-2021, 09:20 PM   #23473
Cedric
Cedric's Avatar
Thunderhill 3 Mile with Ongrid
Not sure if the link will work LOL
The Following 6 Users Say Thank You to Cedric For This Useful Post:
beltax90 (12-20-2021), Lonewolf (12-31-2021), Magoo (12-25-2021), MJones_RB (12-20-2021), NoHaveMSG (12-20-2021), villainous_frx (12-20-2021)
Old 12-20-2021, 12:20 AM   #23474
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Looks like a fun time! How did you mount your camera?
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
Cedric (12-20-2021)
Old 12-20-2021, 02:43 AM   #23475
Cedric
Cedric's Avatar
WHAT DID YOU DO TO YOUR FRS TODAY?
GoPro suction mount on the rear window. Nothing fancy but it gets the job done. All my footage comes out upside down though so going through footage gives me a headache.
Sent from my iPhone using Tapatalk Pro
The Following 2 Users Say Thank You to Cedric For This Useful Post:
villainous_frx (12-20-2021), Wally86 (12-20-2021)
Old 12-20-2021, 05:58 AM   #23476
Compelica
Compelica's Avatar
Drives: 86 GT
Attended a 101 course on braking and control in the middle of a massive downpour. It was postponed soon after - and luckily too as the area was later locked in by rising floods.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following 5 Users Say Thank You to Compelica For This Useful Post:
beltax90 (12-20-2021), Cedric (12-20-2021), macuser27 (12-20-2021), Ultramaroon (12-21-2021), Wally86 (12-20-2021)
Old 12-21-2021, 10:10 AM   #23477
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
DIY sidesplitters
Here's a mock up of my side splitters. It will be 1/8" ABS air dam material and fastened it to bottom of the rocker with double back Gorilla tape and nylon fasteners. It will probably be 98% cosmetic and 2% aero.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (12-28-2021), NoHaveMSG (12-21-2021), Wally86 (12-21-2021)
Old 12-21-2021, 10:50 AM   #23478
Respect on the CAD (cardboard aided design).
blsfrs (12-21-2021), soundman98 (12-21-2021), Wally86 (12-21-2021)
