Old 12-10-2021, 08:20 AM   #23437
StraightOuttaCanadaEh
Wes
Originally Posted by Sasquachulator View Post
Drove on the freeway on monday to a small town just outside the city
....it was cold and slippery...and the rear end kicked out into the next lane a little bit at one point (no one near me thankfully). But i straightened out just as quick....thankfully i didnt lose control.
Was a bit of a dicey drive though, even with my winter tires on. Being just a touch of light snow i dont think it was really sanded or plowed...I even struggled up an incline a little bit (the speed limit was 100km/hr but i struggled to go up any faster than about 75 before the road flattened out)
On my way back home i took an alternate route through the city center which was lower speed and was far more stable feeling lol (and alot more traffic lol).
In the end, did not crash......
I find this car prefers lower tire pressures in the dicey conditions. I do prefer filling to the recommended 35 psi but with snow and such I feel like 32ish is better. I still run 35 though lol
Instagram: @gt86ws
Old 12-10-2021, 12:51 PM   #23438
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Short shifter is about throw, not height. Throw is a little over half stock even at that height.
CAE is porn. I am an IRP peasant.
Ooo, I hadn't run across the IRP before. How do you like it?
Cephas is offline   Reply With Quote
Old 12-10-2021, 01:02 PM   #23439
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s pretty good. It rattles though so it is annoying. On mine I find I have to be more deliberate with my shift into 5th gear when driving hard.
Cephas (12-10-2021)
Old 12-10-2021, 01:33 PM   #23440
Cephas
Cephas's Avatar
Do you have the v3 with the anti-rattle bits? Been reading mixed feedback on that.
Old 12-10-2021, 01:36 PM   #23441
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes it is the updated V3. I believe a lot of it comes from the way it interfaces with the rod from the transmission. The stock shifter has rubber and nylon bits where the shaft goes into the shifter. The IRP has a metal bushing.
Cephas (12-13-2021)
Old 12-12-2021, 06:38 AM   #23442
grumpysnapper
grumpysnapper's Avatar
Originally Posted by Cedric View Post
CAE short shifter installed.
Looks fantastic!
Any rattles at high revs with this unit?
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
Cedric (12-13-2021)
Old 12-12-2021, 09:15 PM   #23443
Decep
Drives: 2013 FR-S Series 10
Installed the whiteline transmission insert (i've had the Perrin rear shifter mount and STI engine mounts installed for a while). For anyone who's installed the Perrin rear shifter mounts, highly recommend you finish the job and add the whiteline transmission insert. It got rid of so much of the bucking/back and forth when coasting or trying to lightly add throttle in stop and go situations. If you're not going to do both i wouldn't do either one.
Noise- a lot more noise in 2nd gear (whining) but i find it fun.
Vibration- a lot more when the engine is cold. When warmed up i can't say its a huge deal.
But these two mods make it so much easier to downshift it's crazy, shifter just snicks into gear whereas before i'd either have to wait for it to slide into gear or just double clutch. Especially downshifting to 2nd gear.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-13-2021, 08:23 PM   #23444
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Car wash and gas. It's cleanish.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
beltax90 (12-14-2021), DarkPira7e (12-28-2021)
Old 12-13-2021, 09:46 PM   #23445
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by grumpysnapper View Post
Looks fantastic!
No rattles
Cedric is offline   Reply With Quote
The Following User Says Thank You to Cedric For This Useful Post:
grumpysnapper (12-14-2021)
Old 12-19-2021, 08:20 PM   #23446
Cedric
Cedric's Avatar
Thunderhill 3 Mile with Ongrid
Not sure if the link will work LOL
The Following 6 Users Say Thank You to Cedric For This Useful Post:
beltax90 (12-20-2021), Lonewolf (12-31-2021), Magoo (12-25-2021), MJones_RB (12-20-2021), NoHaveMSG (12-20-2021), villainous_frx (12-19-2021)
Old 12-19-2021, 11:20 PM   #23447
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Looks like a fun time! How did you mount your camera?
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
Cedric (12-20-2021)
Old 12-20-2021, 01:43 AM   #23448
Cedric
Cedric's Avatar
WHAT DID YOU DO TO YOUR FRS TODAY?
GoPro suction mount on the rear window. Nothing fancy but it gets the job done. All my footage comes out upside down though so going through footage gives me a headache.
Sent from my iPhone using Tapatalk Pro
The Following 2 Users Say Thank You to Cedric For This Useful Post:
villainous_frx (12-20-2021), Wally86 (12-20-2021)
Old 12-20-2021, 04:58 AM   #23449
Compelica
Compelica's Avatar
Drives: 86 GT
Attended a 101 course on braking and control in the middle of a massive downpour. It was postponed soon after - and luckily too as the area was later locked in by rising floods.
DIY stuff at Compelica Works
Compelica is online now   Reply With Quote
The Following 5 Users Say Thank You to Compelica For This Useful Post:
beltax90 (12-20-2021), Cedric (12-20-2021), macuser27 (12-20-2021), Ultramaroon (12-21-2021), Wally86 (12-20-2021)
Old 12-21-2021, 09:10 AM   #23450
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
DIY sidesplitters
Here's a mock up of my side splitters. It will be 1/8" ABS air dam material and fastened it to bottom of the rocker with double back Gorilla tape and nylon fasteners. It will probably be 98% cosmetic and 2% aero.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (12-28-2021), NoHaveMSG (12-21-2021), Wally86 (12-21-2021)
