Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-22-2021, 11:55 AM   #1
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
2022 TPMS backwards compatible?
Can we use prior gen TPMS sensors on the new car? It has a different part number, but...
Anybody know?
Old 11-22-2021, 12:22 PM   #2
azndavepgh
Drives: 2022 BRZ
It looks like the new sensor is a Toyota part used on the Avalon and probably others. I think it should work since it's still 315 MHz. I will know for sure when I get my Winters installed with Tire Rack sensors.
azndavepgh is offline   Reply With Quote
The Following 2 Users Say Thank You to azndavepgh For This Useful Post:
DocWalt (11-22-2021), Frost (11-22-2021)
Old 11-22-2021, 01:21 PM   #3
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That was my plan, I've got my VIN number and just waiting to order the wheels/tires as it'll be my daily for many reasons. Mostly just the fact that RX-8s get truly horrendous fuel economy on short trips when it's cold, lol
Old 11-30-2021, 04:36 PM   #4
azndavepgh
Drives: 2022 BRZ
Update: I assumed that you only needed to match the frequency for a sensor to work, but there may be more to it.
I bought my Winters from Tire Rack with the sensor they sell for the first gen BRZ, which is the Pacific T5. My dealer was able to pair the sensors with the car with no TPMS warning light, but they wouldn't actually give a reading. Then when I tried to reset the TPMS, I got the warning light. I looked up the sensor that Tire Rack sells for the Avalon, and it's the Pacific T6. Both the T5 and T6 are 315 MHz, but I'm guessing that something else is different.
For reference, the manual for the second gen BRZ lists the FCC ID for the sensor as PAXPMVE000. This ID is also found in the manual for the Avalon, and that part is used in many Toyotas.
At this point, I'm going to wait for more definitive information before I do anything else. I can deal with the warning light and check my pressures manually for now.
The Following User Says Thank You to azndavepgh For This Useful Post:
timurrrr (11-30-2021)
Old 11-30-2021, 04:47 PM   #5
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Thanks for the update! I guess the easy answer is just buy the "right" Subaru sensors and have them installed but I'll just hold off until it's sorted.
Old 11-30-2021, 05:17 PM   #6
azndavepgh
Drives: 2022 BRZ
Yep, that's what I get for being an early adopter. I'm going to keep playing around just in case I'm missing something obvious.
I don't mind buying the Subaru part, but it does come at a premium. Especially when it looks like Pacific is the supplier for all of these parts anyway.
Old 12-01-2021, 12:38 AM   #7
eyeballs
Drives: '22 BRZ
I sure hope we don't need to go OEM to get something that works. My local subaru parts guy today said there are currently only 6 sensors in the US at $116 each. After just spending $360 for a set of tires (cyber monday deal), over $500 (after tax) for sensors is hard to swallow. I'm currently waiting to hear back from discount tire as well.
eyeballs is offline   Reply With Quote
Old 12-01-2021, 01:05 PM   #8
azndavepgh
Drives: 2022 BRZ
Assuming the T5 doesn't work, I hope the T6 ends up being the correct sensor. It's in stock and only $42.
Old 12-01-2021, 06:01 PM   #9
dsc_pat
Drives: Too fast
Ian Claypool posted on FB, saying : PSA 2022 car has a new TPMS part number but the previous gen sensors will work and can be had on ebay(used) for about $10 each. Don't spend $600 on new TPMS sensors...
dsc_pat is offline   Reply With Quote
The Following 2 Users Say Thank You to dsc_pat For This Useful Post:
azndavepgh (12-01-2021), Jdmjunkie (12-01-2021)
Old 12-01-2021, 08:09 PM   #10
azndavepgh
Drives: 2022 BRZ
OK, so maybe my dealer just needs to program the sensors again.
Old 12-03-2021, 11:51 AM   #11
azndavepgh
Drives: 2022 BRZ
I went to a different shop and they confirmed the sensors are paired, but still no pressure readings. So I would avoid the Tire Rack sensors for now and go OE.
The Following 4 Users Say Thank You to azndavepgh For This Useful Post:
DocWalt (12-03-2021), Falken86 (12-03-2021), Quagmire (12-03-2021), timurrrr (12-03-2021)
Old 12-03-2021, 01:36 PM   #12
Quagmire
Drives: 22 BRZ LTD Manual Silver
How about Limited owners, if you want a 2nd set will the brz premium wheels and the correct size premium size 215/45 R17 read the exact same Speedo speed as the stock 18’s? I’m considering ordering the premium wheels to go with my winter setup. BUT alas how long to get the premium 17s from Subaru can’t imagine parts are available? I don’t want my mph to be inaccurate. I have looked on tire rack but seeing above probably best with the Toyota Avalon part number for TPMS . oh and do I just trust this website someone shared before… https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Quagmire is offline   Reply With Quote
Old 12-03-2021, 02:10 PM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
When talking about speedo readings, you should be looking at revs/mile (or revs/km) of the desired tire.
Tires of the exact same specified dimensions can still have significantly different revs/mile
According to https://www.michelinman.com/auto/tir...-4?tyreSize=18, 215/40R18 Michelin Pilot Sport 4 make 840 revs/mile.
According to https://www.michelinman.com/auto/tir...-2?tyreSize=17, 215/45R17 Michelin Primacy HP make 844 revs/mile.
That's ~0.5% difference between them, meaning that at 100 mph they are ~0.5 mph off of each other, which most people will never notice.
In fact that's probably less difference than that between a new set of tires and somewhat used.
Since this thread is specifically about TPMS, you may want to start a new thread if you have further questions.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
DocWalt (12-03-2021), Quagmire (12-03-2021)
Old 12-03-2021, 03:13 PM   #14
mangler
Drives: 2007 Saturn Vue
This is a long shot, but do any tunes disable TPMS? I know some harness plug in chips do, but they seem like a lot of money for what they do. As soon as it starts to act odd I would like the option to switch it off...
mangler is offline   Reply With Quote
Intermittent Wipers backwards Runner10 Issues | Warranty | Recalls / TSB 34 09-18-2024 05:22 PM
Schrader 33500 TPMS EZ Sensors compatible with Rays wheels? Infinity Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-07-2020 05:08 PM
Carsguide: the refresh is a step backwards Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 30 03-21-2017 04:31 PM
Someone's backwards response to me on Reddit Linseal Scion FR-S / Toyota 86 GT86 General Forum 14 07-29-2013 01:35 PM
How to make the dealership bend over backwards? Kiteless Scion FR-S / Toyota 86 GT86 General Forum 48 10-30-2011 05:05 PM
