Old 08-10-2014, 08:33 PM   #1
Runner10
Drives: 2014 BRZ Limited
Intermittent Wipers backwards
Has anyone noticed on their BRZ limited that the intermittent wipers are backwards? The wiper frequency increases when I rotate the dial back towards me, and the arrow is pointing at the small side of the spectrum. Are there any quick fixes for this, or is it a dealer thing?
Runner10 is offline   Reply With Quote
Old 08-10-2014, 08:38 PM   #2
humfrz
I'd suggest you just get used to it ......
How about ........ when the arrow is pointing to the "shorter" lines .... this means "a shorter " time between wipes ...
humfrz
Old 08-10-2014, 08:47 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
There are some compromises when making a worldwide platform.
Old 08-10-2014, 08:56 PM   #4
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Could be worse... The JPN spec Del Sol I had while living in the UK had both stalks swapped so the indicators we're on the opposite side. Talk about mind being blown when driving that car and going back and forth with an UK Accord that was normal!
Subaru STI :
Old 08-10-2014, 09:04 PM   #5
Runner10
All fair, but I feel like a brand new car from the factory shouldn't even have minor issues like that. I'll keep looking into it, it's probably pretty easy to correct.
Old 08-11-2014, 02:41 PM   #6
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
This isn't an issue, your car works correctly, check your owners manual, it will say the same thing.
Scenic Driver is offline   Reply With Quote
Old 08-11-2014, 06:32 PM   #7
Ozzman
Drives: old
I'm afraid there is a loose nut behind the wheel, tighten it up and the problem will go away.
Ozzman is offline   Reply With Quote
Old 08-11-2014, 06:53 PM   #8
gramicci101
Off Topic
Recalibrate the throttle actuator.
Old 08-11-2014, 07:55 PM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It's not an issue. It functions the way it was designed to and its accurate based on the increasing symbol of the stalk.
Old 08-11-2014, 08:54 PM   #10
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Threaten the dealership with lemonlaws.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 08-14-2014, 02:20 AM   #11
Poodles
Drives: 2015 Series.Blue
Depending on brand, the intermittent adjustment is one way or another. It's not a screw up, it's just the way certain brands do it simply because there isn't a standard.
Old 08-14-2014, 07:49 AM   #12
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Glad that I'm not the only one that thought it was backwards at first. It's a complete 180 of how my 2012 Toyota Corolla stalk works (even though it's identical in shape and size). Although it makes more sense now, shorter indication, shorter interval. I have learned to live with it.
Frishkorn is offline   Reply With Quote
Old 08-14-2014, 01:37 PM   #13
extrashaky
It's not an "issue."
The indicator on the stalk is not an arrow. It's a line.
At the bottom end the line is thin, indicating that at this position the delay between wipes is small. Turning the knob counter-clockwise makes the wipers work faster.
At the top end the line is fat, indicating that at this position the delay between wipes is large. Turning the knob clockwise makes the wipers work slower.
It doesn't matter how other cars are set up. There is no "standard" way of configuring the wiper control. This is how this one is set up, and if you go looking for a "fix" for something that isn't broken, you'll make yourself look ridiculous.
Old 08-14-2014, 01:56 PM   #14
Luis_GT
A+ thread, would read again
Windshield wipers NMMI89 Cosmetic Modification (Interior/Exterior/Lighting) 34 09-21-2016 11:26 PM
Windshield wipers - a bit too slow? daiheadjai BRZ First-Gen (2012+) — General Topics 62 12-08-2013 07:43 PM
Someone's backwards response to me on Reddit Linseal Scion FR-S / Toyota 86 GT86 General Forum 14 07-29-2013 01:35 PM
Automatic Lights and Wipers for 86? Aventador87 AUSTRALIA 13 06-10-2012 03:05 AM
How to make the dealership bend over backwards? Kiteless Scion FR-S / Toyota 86 GT86 General Forum 48 10-30-2011 05:05 PM
