Old 12-02-2021, 09:09 AM   #1
jamestemperante
Drives: Subaru BRZ
idle dropping when coming to a stop
Hi guys, I've noticed when coming to a stop, the RPM drops making the car shake a bit. also notice this when compressor turns on. Any idea what's going on? I've recently cleaned the throttle body and still does this.
Thanks again for reading my message
jamestemperante is offline   Reply With Quote
Old 12-02-2021, 09:19 AM   #2
jflogerzi
jflogerzi's Avatar
Pretty normal. A tune that raises the idle rpm can help.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
humfrz (12-02-2021), jamestemperante (12-08-2021), Yoshoobaroo (12-02-2021)
Old 12-02-2021, 11:49 AM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea it’s normal for these cars.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 12-03-2021, 12:20 AM   #4
tomm.brz
Drives: brz 2017 hksv2
it s normal... for stock and OFT and tunes that are done quickly or bad.... but some tunes fix it
Old 12-03-2021, 08:12 AM   #5
jamestemperante
Drives: Subaru BRZ
the car has a custom ecutek tune, should i bring it back to the tuner?
Old 12-03-2021, 11:56 PM   #6
jflogerzi
jflogerzi's Avatar
ask him to see if they help tune it out a bit. Unless the car dies or struggles I would not worry bout the dip in rpm..
The Following User Says Thank You to jflogerzi For This Useful Post:
Oil light blinks for 1-2 seconds when coming to a stop/complete stop kev0 Engine, Exhaust, Transmission 27 07-09-2019 11:30 PM
E85 idle question - occasional surge at a stop brillo Software Tuning 4 07-31-2017 10:03 AM
beeping when coming to a stop Skin Issues | Warranty | Recalls / TSB 8 07-24-2017 10:06 AM
OFT - Revs not dropping to idle after WOT and letting off gas justinco Software Tuning 14 01-11-2017 09:38 PM
SOLVED: Idle Dip only when coming to a stop? spatcha88 Issues | Warranty | Recalls / TSB 38 04-14-2015 12:16 AM
