#85 | |
Drives: 2022 BRZ
What size of tire do you plan on getting? |
#86 |
Drives: 1996 Turbo Miata
I'd be fine fitting x9 wheels and tires 235/40. 255's always seemed like a lot of tire for a brz, 235's were plenty grippy on track on my M3.
#87 | |
Senior Citizen
Drives: Scion FR-S
#88 |
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
#89 | |
Drives: 2022 GR86
b) What size of tires do you plan to run? |
#90 |
They are completely custom 3P forged wheels so I can choose any offset I want, I want to stick with 17's so I can run a thicker tire if I choose to, so probably a 235/40 like I have on my BMW
#91 |
Drives: 2022 BRZ
Current setups on my mind (at stock height)...
17x9 +45 RPF1 on 245/40/17 18x8.5 +44 Dekagram on 235/40/18 Mind you I don't even have the car yet. Looking forward to seeing some folks posting any wheel on stock height though. |
#92 | |
Drives: 2022 GR86
My plan so far is to try 245/40 on 17x9 et37 with RLCAs for -2.5º camber, and if that's too wide I can try downsizing to 235/40. |
#93 |
I just ordered some 17X9 +45 to be safe and ill run spacers if they don't sit flush, and ordered some 245/40/17 Pilot Sport AS as well. Hopefully the wheels fit otherwise I'm out $2800 for the wheels and $700 for the tires......
#94 |
Drives: 2022 GR86
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | DocWalt (12-01-2021), Goingnowherefast (12-02-2021) |
#95 |
Drives: '22 WRB
| The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post: | DocWalt (12-01-2021), Goingnowherefast (12-02-2021) |
#96 |
Drives: '23 BRZ Limited
#97 |
Drives: 2022 GR86
Here's 18x9 +50 wrapped into 235/40R18:
![]() Looks like they're using a ~10 mm spacer in the front only to get ~40 effective offset: ![]() Source: Key timestamps: specs at 3:00, close-ups at 0:55 and 1:40; rear brakes (no spacer) at 1:09, front brakes (spacer) at 1:11 and 1:38. |
#98 |
Drives: Moped
I wish Tire Rack would get a Gen 2 in for measurements and test-fitting so that their interactive wheel and tire guide could be used...
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
