Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-30-2021, 02:02 PM   #85
beat1
beat1's Avatar
Drives: 2022 BRZ
Originally Posted by NikolaiCherepanov View Post
Im looking at a set of Heritage Wheels. I was thinking a 17X8.5-9 and a flush fitment on stock suspension, what offset would you recommend? I have been scouring the web to try to find people fitting wheels on the gen 2's but can hardly find much besides what is posted here.
What size of tire do you plan on getting?
beat1 is offline   Reply With Quote
Old 11-30-2021, 02:23 PM   #86
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
I'd be fine fitting x9 wheels and tires 235/40. 255's always seemed like a lot of tire for a brz, 235's were plenty grippy on track on my M3.
Robertw is offline   Reply With Quote
Old 11-30-2021, 02:31 PM   #87
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by trippinbillies40 View Post
You know you can upload pictures too, right? I don't charge royalties if you're not making money off of me :P
I kid, I kid. Here ya go. This is a 17x9+45 with a 255/40/17 Yoko A052. Stock rear camber at -2deg:
I almost pulled the trigger on those Apex wheels today. Decided to hold off and save budget for more important things. Pretty sure those will fit just fine with 245/40's, especially with a tire that's not as wide-per-size as the Yoks or Falkens.
How's the clearance on the inside? So it looks like the rears would ideally want a 17x9 +55 to fit without interference issues under compression?
simpleisbest is offline   Reply With Quote
Old 11-30-2021, 02:38 PM   #88
NikolaiCherepanov
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
Id probably go with a 235/40 profile I definitely dont need thick tires like trippinbillies has.
NikolaiCherepanov is offline   Reply With Quote
Old 11-30-2021, 03:13 PM   #89
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
a) What offset options do they have?
b) What size of tires do you plan to run?
Old 11-30-2021, 03:18 PM   #90
NikolaiCherepanov
They are completely custom 3P forged wheels so I can choose any offset I want, I want to stick with 17's so I can run a thicker tire if I choose to, so probably a 235/40 like I have on my BMW
Old 11-30-2021, 03:26 PM   #91
patsimca
Drives: 2022 BRZ
Current setups on my mind (at stock height)...
17x9 +45 RPF1 on 245/40/17
18x8.5 +44 Dekagram on 235/40/18
Mind you I don't even have the car yet.
Looking forward to seeing some folks posting any wheel on stock height though.
patsimca is offline   Reply With Quote
Old 11-30-2021, 05:44 PM   #92
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I think 235/40 should fit fine on 17x9 et40 wheels.
My plan so far is to try 245/40 on 17x9 et37 with RLCAs for -2.5º camber, and if that's too wide I can try downsizing to 235/40.
Old 11-30-2021, 06:07 PM   #93
NikolaiCherepanov
I just ordered some 17X9 +45 to be safe and ill run spacers if they don't sit flush, and ordered some 245/40/17 Pilot Sport AS as well. Hopefully the wheels fit otherwise I'm out $2800 for the wheels and $700 for the tires......
Old 11-30-2021, 06:11 PM   #94
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
... 245/40/17 Pilot Sport AS ...
In my limited experience, Michelins of any given spec are typically narrower than most other tires with the same spec.
245/40 Michelins will absolutely be narrower than 255/40 A052's
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
DocWalt (12-01-2021), Goingnowherefast (12-02-2021)
Old 11-30-2021, 07:00 PM   #95
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
By a lot.
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
Old 12-06-2021, 10:18 AM   #96
OkieSnuffBox
Drives: '23 BRZ Limited
Could be, but 18x9.5 with 255/35s looked awesome on a Gen 1 with a nice drop.
Old 12-06-2021, 07:11 PM   #97
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Here's 18x9 +50 wrapped into 235/40R18:
Looks like they're using a ~10 mm spacer in the front only to get ~40 effective offset:
Source:
Key timestamps: specs at 3:00, close-ups at 0:55 and 1:40; rear brakes (no spacer) at 1:09, front brakes (spacer) at 1:11 and 1:38.
DocWalt (12-07-2021), dsc_pat (12-07-2021)
Old 12-06-2021, 10:18 PM   #98
Lonewolf
Lonewolf's Avatar
Drives: Moped
I wish Tire Rack would get a Gen 2 in for measurements and test-fitting so that their interactive wheel and tire guide could be used...
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
