#239 |
Drives: '22 WRB
Dyno scheduled for next Tuesday at Drift Office. Testing stock exhaust and the Perrin. Don't expect any real differences but meh, might as well check.
#240 |
Drives: 22 BRZ
Dyno from another thread, just putting it on here for reference. Thanks @Strat_FRS
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#241 |
Drives: GR86 RC
#242 |
Any updates?
2022 BRZ Build 2013 FR-S Build |
#243 |
Drives: '15 BRZ RA
196-200whp on a Dynojet:
#244 |
Drives: 2013 GT86 fully standard
Weird to go all the way to the dyno to do 1-2 runs. Why not several runs while its rigged up and see how the power curve changes, to be sure you have a robust measurment.
#245 |
Drives: 2013 frs red
I'll bet a first gen reads 160 on that dyno.
#246 |
Drives: '22 WRB
Did mine on Tuesday, made 215/171 on a Dynojet. No difference at all with the cat back.
#247 |
Drives: JRSC BRZ SOLD
#248 |
Drives: '15 BRZ RA
#249 |
Drives: 2015 FRS for daily and track use
#250 |
Drives: BRZ 2013
In that video they indicate using a 15% drive train loss correction factor. The Dyno I have nearby is a Maha dyno, which calculates crank hp as well as wheel hp, and in my runs drive train losses vary over the rpm range, but typically would range between 20% and 30% on my gen 1. I found generally 22-23% is a good average. It could be that the gen2 is that much more efficient, but I’ll be curious to see how the gen2 reads on the maha. With 200whp and say 20% drive train loss would be 250 CHP. Anyone has any other data points along those lines ?
At max power, the runs I have seen show drive train losses between 23% and 25% depending on the car., (probably in 4th or 5th gear) Last edited by falcon_wizard; 12-10-2021 at 10:26 AM. |
#251 |
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
Gonna throw up this FB post by Shiv (owner of Open Flash Performance) that was on the FRS/BRZ/86 Enthusiast page showing his personal 2022 BRZ on the dynojet he uses for tuning 86/BRZ’s.
#252 |
Drives: Crapcan
Drift Office posted this on FB.
| Typical Mustang Dyno Numbers? | Rockz222 | Engine, Exhaust, Transmission | 6 | 07-11-2015 08:33 PM |
| Dyno numbers | ogrowup | Engine, Exhaust, Transmission | 7 | 12-27-2014 08:04 AM |
| Average Stock Dyno Numbers? | KONVERTER | Engine, Exhaust, Transmission | 23 | 10-12-2013 10:13 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| dyno numbers seem low | stealth_fighter | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-02-2013 09:01 PM |
