Old 11-24-2021, 07:21 PM   #15
Ohio Enthusiast
Drives: 2018 BRZ
Originally Posted by Capt Spaulding View Post
You could also try this,
a. put the car in neutral and try pushing it.
Then,
b, put it in first and have someone depress the clutch and try pushing it. In my fairly lengthy experience a car in gear with the clutch disengaged is more difficult to push than a car in neutral.
Perfect! Just tried that. I don't think there's constant drag, rather during the first movement of the car the clutch does drags but then it lets go. I'm not sure if that's would happen with the engine on and everything already spinning, but I'm willing to accept that as a possible explanation to what people are describing.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Capt Spaulding (11-24-2021), Ultramaroon (11-25-2021)
Old 11-24-2021, 08:24 PM   #16
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
K As I noted it's nothing like you'd see in a multi-plate wet clutch, but I think its there. How much it does is another question. Enjoy
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 11-24-2021, 08:37 PM   #17
Decep
Drives: 2013 FR-S Series 10
Definitely need to double clutch when the car is cold. Takes a few miles for everything to warm up.
These cars definitely have some Dr Jeckly and Mr Hyde thing going.
Wonder how the new models compare
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 11-25-2021, 12:45 AM   #18
An interesting theory. I'm pretty sure it's wrong, but there's an easy test for it - while standing still with the engine on, depress the clutch pedal. Move the gear lever through the lower gears.
Then rev the engine to high RPM and move the gear lever again. If your theory is correct, there should be a noticeable difference in the movement of the lever. I'll try it out the next time I'm driving.
These guys are right. I double clutch out of super old-school habit and I used to swear that a throttle blip did nothing until I tried it on this car. Damned if a good solid rev way above the target speed didn't do the trick. Then, if timed to help the syncro clutch do its job, instead of replacing it altogether in a double clutch, it actually does work.
I still double clutch because, well, I'm my dad's son.
Old 11-25-2021, 01:37 PM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
H
Just to throw in my 1.5 cent's worth. With clutch pedal fully depressed, there should be absolutely no drag on the clutch surfaces. Otherwise, it would grind every you put the car in reverse.
Old 11-25-2021, 07:38 PM   #20
evidence
Drives: red 2013 frs
thanks :D
i am like new to car community stuff so im kinda stupid but you guys are so nice ily all <3
evidence is offline   Reply With Quote
Old 11-25-2021, 07:55 PM   #21
haha... <3
Old 11-29-2021, 12:30 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Sounds like you're not talking about rev-matching but something else. Rev-matching is hitting the throttle pedal while the clutch is depressed. It only speeds up the flywheel and has no bearing on the transmission whatsoever.
I am talking about rev matching but you are right. I am mistaking the overall smoothness of the process vs. getting the shifter in the gate. I really don't have an issue with my car unless it starts to get under 40F and that is just for the first shift or so.
Ohio Enthusiast (11-29-2021)
problem?
Heel Toe Downshifting henry.haden Scion FR-S / Toyota 86 GT86 General Forum 51 04-14-2020 02:11 PM
Downshifting problem from 5th to 4th n0thing Issues | Warranty | Recalls / TSB 16 01-18-2017 09:57 AM
Downshifting in Autocross smg1138 Tracking / Autocross / HPDE / Drifting 23 05-13-2016 10:41 AM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 10:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 02:20 PM
