Old 04-12-2020, 06:11 PM   #1
henry.haden
Drives: 2013 Subaru BRZ
Heel Toe Downshifting
I’ve been looking into setting up my BRZ for heel toe downshifting. As I am sure you all know, the stock pedal setup is not ideal for this. I am torn between a throttle spacer kit and an Accelerator Pedal. Here are the URLs. Let me know what you all think.
https://www.ft86speedfactory.com/srp...l#.XpORwxZq0lQ
https://www.ft86speedfactory.com/vel...l#.XpOR7hZq0lQ
henry.haden is offline   Reply With Quote
Old 04-12-2020, 06:21 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I have no problem with heel-toe but I have giant feet. Since they make different changes, get both and decide which feels best to you.
Old 04-12-2020, 06:46 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
It's actually pretty good from the factory for me at least. It's set up so you have to be pressing the brake a bit harder/further than you typically might in casual driving.
Old 04-12-2020, 06:53 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have small feet and I have never been very good at it, especially on the street where you are not braking like on track. I used to strap a piece of 2x4 on the bottom of the pedal on one of my cars.
I have both the pedal and the relocator. The pedal is still on the car. I don't think it was worth it, and am going to take it off. I bought the relocator, it is in a box somewhere. Before I could install it, I went FI. One of the goodies on my tune I can turn on and off is auto-blip. I love it.
So I guess I'm not much help.
Old 04-12-2020, 06:55 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
..you have to be pressing the brake a bit harder/further than you typically might in casual driving.
Yep
Old 04-12-2020, 07:02 PM   #6
Windycitystig
Drives:
What tune do you have that allows auto-blip?
Windycitystig is offline   Reply With Quote
Old 04-12-2020, 07:07 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
Coming from a Focus ST, I initially found the BRZ hard to heel and toe. After a time I realized the BRZ is setup for a more classic heel and toe. Most people (myself included) don't really heel and toe - instead you press the brake pedal with the left side of your foot and roll the foot to the right to touch the throttle with the right side of your foot. This worked well for me in the ST and some other manual cars I drove.
The BRZ needs classic heel and toeing - you need to angle your right foot to around 30-45 degrees to the left. This way you press the brake with the ball of your foot and can blip the throttle with the right side of your heel.
I found that the steering column interferes with angling the foot this way a little, so I raised it a little and that helped a lot.
It took a little while to get used to it, but it works easily with the BRZ and allows for better brake control than with the first method I described.
Ohio Enthusiast is offline   Reply With Quote
Old 04-12-2020, 07:15 PM   #8
Ultramaroon
not playing cards
perfect for 7/10+
Old 04-12-2020, 07:15 PM   #9
Tokay444
Anti stance.
Tokay444's Avatar
This car has one of the worst pedal layouts for heel/toe of anything I’ve driven.
That being said, the Verus Engineering throttle pedal spacer makes it absolutely sublime.
Old 04-12-2020, 07:29 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
EcuTek Racerom features. It has launch control, downshift auto blip, flat-foot shifting, and I think a few other. I can switch on the fly with my cruise control stock. Very nice.
Old 04-12-2020, 07:38 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
i use my ankle. i don't know what the rest of you are going on about.
Old 04-12-2020, 08:02 PM   #12
Spuds
The Dictater
Spuds's Avatar
Huh, I suppose that's why people have difficulty with it in these. I learned on my Saab 9-3 where the brake pedal was way too far back, so you had to loop your toe around and press on the brake lever to do it.
Old 04-12-2020, 08:02 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Ok, maybe I'll install mine tomorrow. after all, I've had it for a couple years. Any installment tips?
Old 04-12-2020, 08:47 PM   #14
DarkSunrise
DarkSunrise's Avatar
Haha I'm the exact opposite from you. I learned heel-toe the classic way on Hondas, but started using the ride side of my toes with my STI hatch because the transmission tunnel blocked my heel from reaching the throttle pedal. I find this method still works best for me on the FR-S. It must be really dependent on how people's feet are shaped...
2022 BRZ Build
2013 FR-S Build
Trouble Downshifting into 5th MotoX16 Issues | Warranty | Recalls / TSB 19 10-30-2019 01:50 PM
Downshifting in Autocross smg1138 Tracking / Autocross / HPDE / Drifting 23 05-13-2016 09:41 AM
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 06:59 AM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 09:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 01:20 PM
