Old 11-15-2021, 07:58 AM   #1
letmethefuqin
Drives: 86
Slapping / bouncing feeling when driving slow or changing gears
Be patient with me here,
I’m not to client about gearboxes
Ever since I swiped my clutch out it bunny hops like mad in every great change
At first I thought it was in the tune, but the tuner can’t find an error (I have logs - Ecutek)
So looks to be mechanical
I’ll drive 10km 9’ a straight road in 1st at about 2500
Very light pressure on the throttle and the car feels like it’s driving but something slapping back and forth / bouncing
Can’t figure out what is causing this any suggestions ?
Also before the gear box and clutch change the car always felt like it had a lightened fly wheel which it didn’t, but I felt I had to previously keep the revs up, that seemed to work it’s self out after a re tune though I feel
However in this case it feels possibly more mechanical
Anyone had something similar ?
2012 86 GTS
Heavy duty sprung clutch
Forged fork
Aftermarket pivot
Super pro rear?? Bush
Mtec springs
Motul oil
Rear diff bush compressors
letmethefuqin is offline   Reply With Quote
Old 11-15-2021, 08:14 AM   #2
What make clutch?
Ultramaroon (11-15-2021)
Old 11-15-2021, 03:31 PM   #3
What you say, there, @Ultramaroon - ??
Old 11-15-2021, 03:39 PM   #4
I think @Tcoat's already asked the important question. If it's not a stock clutch, all bets are off.
Old 11-15-2021, 07:07 PM   #5
letmethefuqin
Drives: 86
Just Went and Checked,
It Appears to be a MANTIC Stage 1
Old 11-15-2021, 07:25 PM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
What condition is your trans mount in?
Stock one has a decent amount of slop and can cause bucking in the driveline.
Old 11-15-2021, 08:07 PM   #7
radroach
Drives: car
If you have the rear diff bushings but not the rest of the parts set in the "Positive Traction Kit" from whiteline, you might be getting more play in your rear crossmember and subframe bushings.
I essentially had that problem when I installed whiteline subframe inserts but didn't do the differential bushing until later, the diff was moving around a lot more from stiffening the other parts in the driveline and made it difficult to drive.
Also agree with above that you might be getting slop from the transmission bushing.
Old 11-15-2021, 08:52 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
This sounds to me like the new clutch is more aggressive than your old one and you need to adjust to it and possibly give it time to bed in also.
This sounds like drivetrain slop. These cars had some even from brand new. How many kms has your car done? It may just need some bushes replaced.
Subaru motors have small, lightweight crankshafts and usually feel more like a lightened flywheel compared to a normal inline 4cyl engine.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 11-15-2021, 11:14 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
was the drive shaft removed at any point for any of this work?
was it clocked correctly?
Old 11-16-2021, 07:40 AM   #10
Not familiar with that brand but a quick look shows that it is indeed quite aggressive. As Turd says you may need a bit longer "break in" period for it.
If that doesn't do it then like a few have said you could move onto bushings but the most probable cause is what you changed so start with the clutch itself and work back from there.
Old 11-16-2021, 12:40 PM   #11
The whole driveline is pretty squishy. Couple that with the CV-joint lash and, as @Tcoat has experienced with me hooning in wet patches, it's a recipe for some nasty flutter. I suggest simply going back to a less aggressive (stock) clutch. It's rated specifically for the strength of the transmission anyway.
soundman98 (11-16-2021), Tcoat (11-16-2021)
Old 11-17-2021, 01:48 AM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
What make clutch?
The Following User Says Thank You to x808drifter For This Useful Post:
Ultramaroon (11-17-2021)
Coilover ride height changing while driving? Whooosah Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-04-2018 05:50 PM
Driving slow hearing sound on driver side like metal hitting eachother Frs32907 Issues | Warranty | Recalls / TSB 19 09-04-2013 10:55 PM
Changing Gears Naughty AFRICA 10 01-09-2013 12:30 PM
Driving habits changing jflogerzi Scion FR-S / Toyota 86 GT86 General Forum 34 11-23-2012 07:11 PM
driving in 1st weak/stuttering feeling deedz Scion FR-S / Toyota 86 GT86 General Forum 19 07-25-2012 06:33 PM
